[Swift-user] Re: [falkon-user] 1) disable retry mechanism and 2) continue on failure?
Ben Clifford
benc at hawaga.org.uk
Thu Apr 3 04:43:27 CDT 2008
On Wed, 2 Apr 2008, Ioan Raicu wrote:
> 1 Node Perf Falkon Swift+Falkon Swift+Falkon (patched)
> Min 63.618 53.782 169.139 58.538
> Average 64.76 65.47253 309.1945 80.21246
> Median 64.74072 64.774 313.5535 76.5245
> Max 65.863 94.447 605.654 115.237
> Standard Deviation 0.488984 3.863944 52.13821
> 10.95652
> Efficiency 100% 99% 21% 81%
> The first column shows the per task statistic when running on 1 node (4 CPUs)
> through Falkon. The second column are the statistics for running the
> application at large scale, on 2048 CPUs. The 3rd column is running
> Swift+Falkon (both from SVN) on 256 CPUs. The 4th column is Swift+Falkon, but
> Swift has the 3 patches applied. Essentially, the per task execution time was
> reduced from 309 seconds to 80 seconds, where the ideal would have been 64
> seconds. It brought the efficiency from 21% to 81% for this particular
> workload. This looks fantastic!
The standard deviation is quite large for the patched-swift values. I'd be
interested to see the -info files for all of these runs so I can see what
they are doing. Can you put them somewhere for me?
More information about the Swift-user
