[Swift-user] Success with fork, but exception in getFile with condor
Mihael Hategan
hategan at mcs.anl.gov
Mon Sep 10 17:46:45 CDT 2007
The wrapper produces exactly one status file: <jobid>-success or
<jobid>-error. If none is present it means that either the very unlikely
thing that the wrapper didn't write any of them, due to some weird thing
I'm missing, or that GridFTP on the head node doesn't see what the
wrapper has written.
On Mon, 2007-09-10 at 16:42 -0500, Jing Tie wrote:
> Hi,
> I think there is a problem running swift script with jobmanager-condor
> on some OSG sites. I run simple-wf.dtm (very simple swift script to
> copy content of input file to output file) and SID script on GLOW site
> separately. Everything is great when running by jobmanager-fork, but
> "exception in getFile" happened with jobmanager-condor. The log from
> swift client is attached. However, no log/info/output files were
> generated in the swift work cache, neither was any duplicate-***
> directory, though in the log file the directory seemed had been
> created.
> The site GLOW (cmsgrid01.hep.wisc.edu) can successfully run
> globus-url-copy, copy files between OSG_DATA and OSG_WN_TMP.
> Exception:
> Task(type=2, identity=urn:0-0-1189455037519) setting status to Failed
> Exception in getFile
> File transfer failed
> duplicate failed
> The following errors have occurred:
> 1. Application "duplicate" failed (No status file was found. Check the
> shared filesystem on GLOW)
> Arguments: "simpleFile.txt"
> Host: GLOW
> Directory: simple-wf-7l8vqstrkud90/duplicate-7niqt1hi
> STDERR:
> STDOUT:
> Thanks,
> Jing
> Swift-user mailing list
> Swift-user at ci.uchicago.edu
> http://mail.ci.uchicago.edu/mailman/listinfo/swift-user
More information about the Swift-user
