[Swift-user] Success with fork, but exception in getFile with condor
Jing Tie tiejing at gmail.com
Mon Sep 10 16:42:39 CDT 2007
I think there is a problem running swift script with jobmanager-condor
on some OSG sites. I run simple-wf.dtm (very simple swift script to
copy content of input file to output file) and SID script on GLOW site
separately. Everything is great when running by jobmanager-fork, but
"exception in getFile" happened with jobmanager-condor. The log from
swift client is attached. However, no log/info/output files were
generated in the swift work cache, neither was any duplicate-***
directory, though in the log file the directory seemed had been
created.
The site GLOW (cmsgrid01.hep.wisc.edu) can successfully run
globus-url-copy, copy files between OSG_DATA and OSG_WN_TMP.
Exception:
Task(type=2, identity=urn:0-0-1189455037519) setting status to Failed
Exception in getFile
File transfer failed
duplicate failed
The following errors have occurred:
1. Application "duplicate" failed (No status file was found. Check the
shared filesystem on GLOW)
        Arguments: "simpleFile.txt"
        Host: GLOW
        Directory: simple-wf-7l8vqstrkud90/duplicate-7niqt1hi
        STDERR:
        STDOUT:
Jing
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/swift-user/attachments/20070910/5253b221/attachment.obj>
More information about the Swift-user mailing list
