[Swift-user] #!/bin/bang
Ben Clifford benc at hawaga.org.uk
Mon Oct 1 04:47:16 CDT 2007
I've seen this happen a couple of times recently from different people, so
here's a note about it.
When writing a unix script, you should put the first line to be the
interpreter specification (such as #!/bin/bash or #!/usr/bin/perl).
This must be on the very first line, so that the first two bytes of the
file are #!
If you are writing a shell script and omit that, you will find that in
some contexts the shell script will run successfully and in other contexts
it will not work.
The specific example I've seen in swift is running shell scripts from
swift - if you omit the initial #!/bin/bash, then: if you run with
kickstart, they will not work; if you run without kickstart, they will
work (because of the different ways in which the kickstart and
non-kickstart mechanisms invoke executables). If the #!/bin/bash is
present, then the script will work in both cases.
More information about the Swift-user mailing list
