[Swift-user] Passing strings with blanks to apps in swift
Mihael Hategan
hategan at mcs.anl.gov
Thu Nov 8 13:03:10 CST 2007
On Thu, 2007-11-08 at 18:56 +0000, Ben Clifford wrote:
> On Thu, 8 Nov 2007, Mihael Hategan wrote:
> > If you put the string in quotes it should work. One string is one
> > element in argv.
> some of the GRAM2 jobmanagers don't deal with that - I know condor
> doesn't.
Don't use the condor job manager then.
> > On Thu, 2007-11-08 at 12:20 -0600, Michael Wilde wrote:
> > > In angle i need to pass a string of IDs as a single parameter to an
> > > application:
> > > angle "7171717 76 76" --more stuff --here
> > > Can you point me to an example of how to pass/quote this correctly, so
> > > that the command line is invoked exactly as above (in this case with
> > > argc=5, and argv[1]="7171717 76 76" ?
> > > Thanks.
> > > _______________________________________________
> > > Swift-user mailing list
> > > Swift-user at ci.uchicago.edu
> > > http://mail.ci.uchicago.edu/mailman/listinfo/swift-user
More information about the Swift-user
