[Swift-user] Passing strings with blanks to apps in swift
Ben Clifford benc at hawaga.org.uk
Thu Nov 8 12:56:46 CST 2007
On Thu, 8 Nov 2007, Mihael Hategan wrote:
> If you put the string in quotes it should work. One string is one
> element in argv.
some of the GRAM2 jobmanagers don't deal with that - I know condor
doesn't.
> On Thu, 2007-11-08 at 12:20 -0600, Michael Wilde wrote:
> > In angle i need to pass a string of IDs as a single parameter to an
> > application:
> >    angle "7171717 76 76" --more stuff --here
> > Can you point me to an example of how to pass/quote this correctly, so
> > that the command line is invoked exactly as above (in this case with
> > argc=5, and argv[1]="7171717 76 76" ?
> > Thanks.
> > _______________________________________________
> > Swift-user mailing list
> > Swift-user at ci.uchicago.edu
> > http://mail.ci.uchicago.edu/mailman/listinfo/swift-user
More information about the Swift-user mailing list
