[Swift-user] Job bundles
Ioan Raicu iraicu at cs.uchicago.edu
Tue Nov 6 11:53:30 CST 2007
I had a similar discussion with Nika, and here was the summary of what I
told her (in the context of GRAM4):
GRAM4 has two elements that dictate how many nodes and processes it gets
(in the XML RSL).
<count>processCount</count>
<hostCount>hostCount</hostCount>
The <hostCount> is the number of nodes you want, say 1.  The <count> is
the number of processes that you want to start in total.  To compute the
number of processes per node, you would simply take
processCount/hostCount.  Now, the catch is that all the commands and
argument to the particular GRAM4 call will have to be the same, so you
won't be able to specify to GRAM that you want 8 processes per node say,
but to run a different process for each of those 8.  You will have to
have this kind of logic internally in your app.  If Swift works the way
I think it works, I don't think you will be able to use multiple
processors unless at least one of the following is true:
1) the application is already multi-threaded, and implicitly can use
multiple cores
2) the LRM allows the partitioning of the SMP machine into smaller
pieces; for example, with 8 processor node, if it lets you submit 8 jobs
that only need 1 processor, and it will launch 8 different jobs on the
same node, then you are fine... the parallelism will be done
automatically by the LRM, as long as you ask for only 1 process at a
time; on the TG at least, I don't think this is how things work, and
when you get a node, regardless of how many processors it has, you get
full access to all processors, not just the ones you asked for.
3) the bundling component in Swift somehow should be able to control how
many concurrent jobs it should perform; by default, I suppose it
serializes the entire bundle, but you could imagine having a parameter
that allows you to increase the parallelism if you know the application
is not CPU bound for example
Choices #1 and #2 are the easiest, as you don't have to do anything
special from Swift's point of view.  Choice #3 requires that Swift
handle the parallelism.  GRAM4 as far as I know will not handle this.
Maybe the Swift team can shed more light on option #3, if there is such
an option.
Ioan
Yuqing Deng wrote:
> Hi,
>  I am using swift to run workflow on login-abe.ncsa.teragrid.org at
> ncsa.  Abe is allocated on node basis.  Each of the node has 8
> computing cores.  My jobs are all serial.  What happens is that only
> one jobs runs on one core per node.  It there a way to bundle jobs so
> that 8 of them
> could run simultaneously on a node?  I have tried to use
>    <profile namespace="globus" key="xcount">8</profile>
>    <profile namespace="globus" key="host_xcount">1</profile>
> in the sites.xml file.  But doing that seems to run the same job eight
> times on a node.
>  Thanks,
>  Yuqing
> Swift-user mailing list
> Swift-user at ci.uchicago.edu
> http://mail.ci.uchicago.edu/mailman/listinfo/swift-user
Ioan Raicu
Ph.D. Student
Distributed Systems Laboratory
Computer Science Department
University of Chicago
1100 E. 58th Street, Ryerson Hall
Chicago, IL 60637
Email: iraicu at cs.uchicago.edu
Web:   http://www.cs.uchicago.edu/~iraicu
       http://dsl.cs.uchicago.edu/
More information about the Swift-user mailing list
