[Swift-user] Kickstart executable not found
Mihael Hategan
hategan at mcs.anl.gov
Sun Aug 19 20:51:04 CDT 2007
On Sat, 2007-08-18 at 18:24 -0500, Jing Tie wrote:
> Hi,
> I am working on SID application now. Job cwtsmall is a script
> wavelet.sh on AGLT2 site. In the wavelet.sh, R runs runWaveletsAvg.R
> on input data 101_FB-epochs.Rdata, and should output
> 101-FBchannel1_cwt-avgResults.Rdata to
> 101-FBchannel28_cwt-avgResults.Rdata
> these 28 files.
> But when I runed swift client with kickstart.enabled = false,
Where did you set this?
Mihael
> it had
> the exit code 1024 error. And the stderr.txt said: Kickstart
> executable (101-FBchannel18_cwt-avgResults.Rdata) not found. Details
> below:
> site: AGLT2
> gatekeeper: gate01.aglt2.org
> app_dir: /atlas/data08/OSG/APP/SIDGrid
> data_dir: /atlas/data08/OSG/DATA
> condor_dir: /opt/condor/bin
> R_dir: /atlas/data08/OSG/APP/R-2.5.1/bin/R
> output:
> Application exception: Job cwtsmall failed with an exit code of 1024
> sys:throw @ vdl-int.k, line: 109
> vdl:checkexitcode @ vdl-int.k, line: 370
> vdl:execute2 @ execute-default.k, line: 22
> vdl:execute @ sid-wf1.kml, line: 20
> wavelettransf @ sid-wf1.kml, line: 362
> batchtrials @ sid-wf1.kml, line: 402
> vdl:mains @ sid-wf1.kml, line: 399
> cwtsmall failed
> Provenance graph saved in sid-wf1-8cnxmo0qetg10.dot
> The following errors have occurred:
> 1. Application "cwtsmall" failed (Job cwtsmall failed with an exit code of 1024)
> Arguments: "scripts/runWaveletsAvg.R, 101, FB"
> Host: NWICG_NotreDame
> Directory: sid-wf1-8cnxmo0qetg10/cwtsmall-zeb72rfi
> STDERR: Kickstart executable
> STDOUT:
> Errors detected. Cleanup not done.
> Execution completed with errors
> sys:throw @ vdl.k, line: 140
> at org.globus.cog.karajan.workflow.nodes.FlowNode.fail(FlowNode.java:413)
> at org.globus.cog.karajan.workflow.nodes.FlowNode.fail(FlowNode.java:417)
> at org.globus.cog.karajan.workflow.nodes.GenerateErrorNode.post(GenerateErrorNode.java:28)
> at org.globus.cog.karajan.workflow.nodes.AbstractSequentialWithArguments.childCompleted
> at org.globus.cog.karajan.workflow.nodes.Sequential.notificationEvent(Sequential.java:33)
> at org.globus.cog.karajan.workflow.nodes.FlowNode.event(FlowNode.java:334)
> at org.globus.cog.karajan.workflow.events.EventBus.send(EventBus.java:123)
> at org.globus.cog.karajan.workflow.events.EventBus.sendHooked(EventBus.java:97)
> at org.globus.cog.karajan.workflow.nodes.FlowNode.fireNotificationEvent(FlowNode.java:172)
> at org.globus.cog.karajan.workflow.nodes.FlowNode.complete(FlowNode.java:298)
> at org.globus.cog.karajan.workflow.nodes.functions.AbstractFunction.executeChildren(AbstractFunction.java:37)
> at org.globus.cog.karajan.workflow.nodes.FlowContainer.execute(FlowContainer.java:63)
> at org.globus.cog.karajan.workflow.nodes.FlowNode.restart(FlowNode.java:239)
> at org.globus.cog.karajan.workflow.nodes.FlowNode.start(FlowNode.java:280)
> at org.globus.cog.karajan.workflow.nodes.FlowNode.controlEvent(FlowNode.java:392)
> at org.globus.cog.karajan.workflow.nodes.FlowNode.event(FlowNode.java:331)
> at org.globus.cog.karajan.workflow.FlowElementWrapper.event(FlowElementWrapper.java:227)
> at org.globus.cog.karajan.workflow.events.EventWorker.run(EventWorker.java:69)
> I found that there are about 8 sites in OSG having the problem.
> Many thanks,
> Jing
> Swift-user mailing list
> Swift-user at ci.uchicago.edu
> http://mail.ci.uchicago.edu/mailman/listinfo/swift-user
More information about the Swift-user
