[Swift-user] Kickstart executable not found
Jing Tie tiejing at gmail.com
Sat Aug 18 18:24:20 CDT 2007
I am working on SID application now. Job cwtsmall is a script
wavelet.sh on AGLT2 site. In the wavelet.sh, R runs runWaveletsAvg.R
on input data 101_FB-epochs.Rdata, and should output
101-FBchannel1_cwt-avgResults.Rdata to
101-FBchannel28_cwt-avgResults.Rdata
these 28 files.
But when I runed swift client with kickstart.enabled = false, it had
the exit code 1024 error. And the stderr.txt said: Kickstart
executable (101-FBchannel18_cwt-avgResults.Rdata) not found. Details
below:
site: AGLT2
gatekeeper: gate01.aglt2.org
app_dir: /atlas/data08/OSG/APP/SIDGrid
data_dir: /atlas/data08/OSG/DATA
condor_dir: /opt/condor/bin
R_dir: /atlas/data08/OSG/APP/R-2.5.1/bin/R
output:
Application exception: Job cwtsmall failed with an exit code of 1024
        sys:throw @ vdl-int.k, line: 109
        vdl:checkexitcode @ vdl-int.k, line: 370
        vdl:execute2 @ execute-default.k, line: 22
        vdl:execute @ sid-wf1.kml, line: 20
        wavelettransf @ sid-wf1.kml, line: 362
        batchtrials @ sid-wf1.kml, line: 402
        vdl:mains @ sid-wf1.kml, line: 399
cwtsmall failed
Provenance graph saved in sid-wf1-8cnxmo0qetg10.dot
The following errors have occurred:
1. Application "cwtsmall" failed (Job cwtsmall failed with an exit code of 1024)
        Arguments: "scripts/runWaveletsAvg.R, 101, FB"
        Host: NWICG_NotreDame
        Directory: sid-wf1-8cnxmo0qetg10/cwtsmall-zeb72rfi
        STDERR: Kickstart executable
        STDOUT:
Errors detected. Cleanup not done.
Execution completed with errors
        sys:throw @ vdl.k, line: 140
        at org.globus.cog.karajan.workflow.nodes.FlowNode.fail(FlowNode.java:413)
        at org.globus.cog.karajan.workflow.nodes.FlowNode.fail(FlowNode.java:417)
        at org.globus.cog.karajan.workflow.nodes.GenerateErrorNode.post(GenerateErrorNode.java:28)
        at org.globus.cog.karajan.workflow.nodes.AbstractSequentialWithArguments.childCompleted
        at org.globus.cog.karajan.workflow.nodes.Sequential.notificationEvent(Sequential.java:33)
        at org.globus.cog.karajan.workflow.nodes.FlowNode.event(FlowNode.java:334)
        at org.globus.cog.karajan.workflow.events.EventBus.send(EventBus.java:123)
        at org.globus.cog.karajan.workflow.events.EventBus.sendHooked(EventBus.java:97)
        at org.globus.cog.karajan.workflow.nodes.FlowNode.fireNotificationEvent(FlowNode.java:172)
        at org.globus.cog.karajan.workflow.nodes.FlowNode.complete(FlowNode.java:298)
        at org.globus.cog.karajan.workflow.nodes.functions.AbstractFunction.executeChildren(AbstractFunction.java:37)
        at org.globus.cog.karajan.workflow.nodes.FlowContainer.execute(FlowContainer.java:63)
        at org.globus.cog.karajan.workflow.nodes.FlowNode.restart(FlowNode.java:239)
        at org.globus.cog.karajan.workflow.nodes.FlowNode.start(FlowNode.java:280)
        at org.globus.cog.karajan.workflow.nodes.FlowNode.controlEvent(FlowNode.java:392)
        at org.globus.cog.karajan.workflow.nodes.FlowNode.event(FlowNode.java:331)
        at org.globus.cog.karajan.workflow.FlowElementWrapper.event(FlowElementWrapper.java:227)
        at org.globus.cog.karajan.workflow.events.EventWorker.run(EventWorker.java:69)
I found that there are about 8 sites in OSG having the problem.
Many thanks,
Jing
More information about the Swift-user mailing list
