[Swift-devel] qsub env
Ketan Maheshwari
ketan at mcs.anl.gov
Fri May 8 13:34:27 CDT 2015
Hi Mihael,
I am trying to pass an environment variable at the qsub level.
In the Swift source, CobalExecutor.java, I find the following code as part
of qsub commandline builder:
Collection<String> names = getSpec().getEnvironmentVariableNames();
if (names != null && names.size() > 0) {
result.add("--env");
StringBuffer sb = new StringBuffer();
Iterator<String> i = names.iterator();
while (i.hasNext()) {
String name = i.next();
sb.append(name);
sb.append('=');
sb.append(quote(getSpec().getEnvironmentVariable(name)));
if (i.hasNext()) {
sb.append(':');
result.add(sb.toString());
I am wondering how to add my environment variable to this list.
Ketan
On Fri, May 8, 2015 at 1:18 PM, Mihael Hategan <hategan at mcs.anl.gov> wrote:
> Are you trying to pass an environment variable to an app or to the
> worker?
> Mihael
> On Fri, 2015-05-08 at 13:00 -0500, Ketan Maheshwari wrote:
> > Hi,
> > Question about the cobalt provider with 0.96: how to set an environment
> so
> > that it ends up on the qsub line:
> > qsub --env MY_ENV=true ...
> > I tried to add the env.MY_ENV line under site.cluster
> > and site.cluster.execution.options but to no avail.
> > From logs of my current runs, I see that the qsub line contains one
> > environment variable:
> > qsub --env WORKER_LOGGING_LEVEL=NONE --mode script --proccount 32 ...
> > but I do not see it being specified anywhere in my conf file.
> > Thanks for any suggestions.
> > Ketan
> > _______________________________________________
> > Swift-devel mailing list
> > Swift-devel at ci.uchicago.edu
> > https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-devel
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20150508/07ad2ecb/attachment.html>
