[Swift-devel] qsub env
    Mihael Hategan
    hategan at mcs.anl.gov
    Fri May  8 13:18:29 CDT 2015
Are you trying to pass an environment variable to an app or to the
worker?
Mihael
On Fri, 2015-05-08 at 13:00 -0500, Ketan Maheshwari wrote:
> Hi,
> Question about the cobalt provider with 0.96: how to set an environment so
> that it ends up on the qsub line:
> qsub --env MY_ENV=true ...
> I tried to add the env.MY_ENV line under site.cluster
> and site.cluster.execution.options but to no avail.
> From logs of my current runs, I see that the qsub line contains one
> environment variable:
> qsub --env WORKER_LOGGING_LEVEL=NONE --mode script --proccount 32 ...
> but I do not see it being specified anywhere in my conf file.
> Thanks for any suggestions.
> Ketan
> Swift-devel mailing list
> Swift-devel at ci.uchicago.edu
> https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-devel
