[Swift-devel] Updating swift-lang for 0.96.0
    Ketan Maheshwari
    ketan at mcs.anl.gov
    Fri May  8 12:40:01 CDT 2015
Looks good to me.
Comments:
-- in the release number we had two parts x.xx (0.95) whereas in this one
it is x.xx.x (0.96.0). Intentional?
-- Release notes points to 404 not found (may be disable link for now?)
-- Configuration file format link points to your home www area, may be
point to github conf schema link (
https://github.com/swift-lang/swift-k/blob/master/resources/swift.conf.schema)
or swift-lang.org area.
On Fri, May 8, 2015 at 11:06 AM, Yadu Nand Babuji <yadunand at uchicago.edu>
wrote:
> Hi All,
> I'm updating swift-lang.org for the 0.96.0 release, and should be done
> in an hour.
> I would really appreciate it if folks could try links and go over the
> website text to
> check if everything is in order.
> Thanks,
> Yadu
> Swift-devel mailing list
> Swift-devel at ci.uchicago.edu
> https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-devel
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20150508/faac0609/attachment.html>
