[Swift-devel] assertion behavior
Tim Armstrong tim.g.armstrong at gmail.com
Fri Mar 27 21:58:44 CDT 2015
I feel like that is getting away from what assertions are intended to be -
the best thing about them is that they're dead simple and have a clear,
well-defined use case.  I don't think that should be compromised out of a
desire to have them serve dual purposes.
- Tim
On 27 March 2015 at 12:28, Justin M Wozniak <wozniak at mcs.anl.gov> wrote:
> Catchable/soft assertion failures would be useful if we rewrote the test
> suite in Swift.  Maybe we should do that anyway.
> On 3/27/2015 9:39 AM, Tim Armstrong wrote:
>  I don't think it makes sense to treat it as a soft error.
> The primary use case for assertions is the Swift/T test suite and there's
> no reason to continue running after an assertion failure.
> If a user wants to use them in their own scripts, they're intended to
> catch bugs or unintended behaviour.  If an assertion fails, the script is
> not doing what it's meant to be doing.  I don't see any reason to keep on
> running a buggy script that failed an assertion, and I see plenty of
> reasons not to keep it running.
>  If users want to disable their assertions there is support for that.
>  - Tim
> On 27 March 2015 at 09:20, Michael Wilde <wilde at anl.gov> wrote:
>>  Does "terminate immediately" need to always be immediate or should/could
>> it integrate with the Swift/K notion of "soft errors"?
>> I.e. an assert failure is treated like a failing function; that in turn
>> as handled as the soft-error property specifies.
>> - Mike
>> On 3/25/15 10:24 PM, Tim Armstrong wrote:
>>  The program terminates immediately with an error message.
>> There's a compile-time option to disable assertions if needed.  It's
>> actually a little weird in that it syntactically removes the statement - it
>> doesn't evaluate the arguments to the funciton.
>>  - Tim
>> On 25 March 2015 at 22:09, Mihael Hategan <hategan at mcs.anl.gov> wrote:
>>> Hi,
>>> In Swift/T, what happens when an assertion fails?
>>> Mihael
>>> _______________________________________________
>>> Swift-devel mailing list
>>> Swift-devel at ci.uchicago.edu
>>> https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-devel
>> Swift-devel mailing listSwift-devel at ci.uchicago.eduhttps://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-devel
>> Michael Wilde
>> Mathematics and Computer Science          Computation Institute
>> Argonne National Laboratory               The University of Chicago
> Justin M Wozniak
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20150327/a3951a89/attachment.html>
