[Swift-devel] assertion behavior
    Justin M Wozniak
    wozniak at mcs.anl.gov
    Fri Mar 27 12:28:07 CDT 2015
Catchable/soft assertion failures would be useful if we rewrote the test
suite in Swift.  Maybe we should do that anyway.
On 3/27/2015 9:39 AM, Tim Armstrong wrote:
> I don't think it makes sense to treat it as a soft error.
> The primary use case for assertions is the Swift/T test suite and
> there's no reason to continue running after an assertion failure.
> If a user wants to use them in their own scripts, they're intended to
> catch bugs or unintended behaviour.  If an assertion fails, the script
> is not doing what it's meant to be doing.  I don't see any reason to
> keep on running a buggy script that failed an assertion, and I see
> plenty of reasons not to keep it running.
> If users want to disable their assertions there is support for that.
> - Tim
> On 27 March 2015 at 09:20, Michael Wilde <wilde at anl.gov
> <mailto:wilde at anl.gov>> wrote:
>     Does "terminate immediately" need to always be immediate or
>     should/could it integrate with the Swift/K notion of "soft errors"?
>     I.e. an assert failure is treated like a failing function; that in
>     turn as handled as the soft-error property specifies.
>     - Mike
>     On 3/25/15 10:24 PM, Tim Armstrong wrote:
>>     The program terminates immediately with an error message.
>>     There's a compile-time option to disable assertions if needed.
>>     It's actually a little weird in that it syntactically removes the
>>     statement - it doesn't evaluate the arguments to the funciton.
>>     - Tim
>>     On 25 March 2015 at 22:09, Mihael Hategan <hategan at mcs.anl.gov
>>     <mailto:hategan at mcs.anl.gov>> wrote:
>>         Hi,
>>         In Swift/T, what happens when an assertion fails?
>>         Mihael
>>         _______________________________________________
>>         Swift-devel mailing list
>>         Swift-devel at ci.uchicago.edu <mailto:Swift-devel at ci.uchicago.edu>
>>         https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-devel
>     Michael Wilde
>     Mathematics and Computer Science          Computation Institute
>     Argonne National Laboratory               The University of Chicago
Justin M Wozniak
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20150327/8412b93e/attachment.html>
