[Swift-devel] Standard Library Proposal/Discussion Page
    Tim Armstrong
    tim.g.armstrong at gmail.com
    Fri Jan 23 11:25:47 CST 2015
There's a Swift/T issue for this, btw, if that's of any relevance.
I think the low-hanging fruit of consistent names for common functions have
the highest impact here, so I agree we can move forward on the easy things.
- Tim
On Thu, Jan 22, 2015 at 10:42 PM, Mihael Hategan <hategan at mcs.anl.gov>
wrote:
> On Thu, 2015-01-22 at 16:04 -0800, Mihael Hategan wrote:
> > It is not clean, or at least I don't see how it can be made clean. In
> > particular because no function in swift should behave differently
> > depending on when it is run or if it is run multiple times. This is
> > called referential transparency and it says that all f(x) will always
> > have the same value when invoked with the same x. It is the only way I
> > know to guarantee that the not-fully-specified ordering of execution in
> > swift results in correct programs.
> This does seem to fit into the idea of side effects contained into an
> app specification. That is, however, another issue I think.
> So I'm not sure. I would like to avoid contentious issues if possible.
> Otherwise we might spent too much time on this. Can we keep it to stuff
> that doesn't touch on filesystem manipulation and other known weird
> things?
> I think there are some functions on that page that are already tricky
> and should be removed, so, that's probably plenty for now.
> Mihael
> Swift-devel mailing list
> Swift-devel at ci.uchicago.edu
> https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-devel
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20150123/620abfc3/attachment.html>
