[Swift-devel] Standard Library Proposal/Discussion Page
Yadu Nand Babuji
yadunand at uchicago.edu
Thu Jan 22 14:14:04 CST 2015
Hi MIhael,
Now that I write that snippet/pseudocode, I think baseName and dirName
would also be useful.
Perhaps stat, is redundant because I can use a mapper for the same result.
How do you loop sanely in swift. Well that is a tough question.
On 01/22/2015 12:41 PM, Mihael Hategan wrote:
> On Thu, 2015-01-22 at 12:17 -0600, Yadu Nand Babuji wrote:
>> Hi Mihael,
>> e
>> I have a request for the some features similar to those provided by
>> python's os library:
>> getcwd
> Sure. Perhaps getEnv()?
Sure getEnv works just as well.
>> remove (/rm)
>> move ? ( python doesn't seem to have this)
> Like move and remove files? Do you have an example of how these would be
> used?
I remember a case where a directory is actively getting filled with data
that needs to be processed.
So, we map the input_queue directory, "move" the file to the active
directory and start the processing.
file active_files[] <simple_mapper; location="active_list",
prefix="active"> ;
file completed[];
iterate ( ){
file new_files[] = <simple_mapper; location="input_queue",
prefix="foo">;
foreach f in new_files{
move ( f, active_files[length(active_files)] ); # We
move the file, so that it is not processed again in the next round.
completed[length(completed)] = process(active_file);
sleep(60);
}until ( status == 10000 );
I do not have a use-case that generates large intermediate files, which
need to be removed mid-way through processing.
>> stat ( For loops which stat for new files )
> Stat on a given file, yes (and there are some question marks there,
> too), stat to poll for files being added to a directory? I'm not sure.
> How do you even loop sanely in swift? Do you have a specific
> need/example?
Perhaps stat is redundant since you can do the same check with a mapper ?
I do not know how to answer the "how to loop sanely" question.
The example is the same is the one above.
>> system ( fix ? )
> Sure. Although I'd like Tim's and Justin's input on this.
> Mihael
