[Swift-devel] Feature proposal: struct constructors
Ketan Maheshwari
ketan at mcs.anl.gov
Wed Feb 4 13:05:38 CST 2015
I would suggest we change the naming from constructors to something else as
it has some associated OO connotations.
On Tue, Feb 3, 2015 at 4:54 PM, Tim Armstrong <tim.g.armstrong at gmail.com>
wrote:
> Hi All,
> While designing a location-aware feature for Swift/T Justin and I came
> across a scenario where we wanted to use Swift structs, but where it was
> very painful to assign each element individually. To give you an idea:
> type foo {
> int x;
> int y;
> foo bar;
> bar.x = 1;
> bar.y = 2;
> I'm looking at adding a feature where we can fill in a structs fields with
> a single expression.
> We could do them the C-style way, but that doesn't allow us to use them
> without defining a new variable (the issue is that {} doesn't specify the
> intended type, meaning it needs to come from context):
> foo bar = { 1, 2 };
> I was thinking that we should just have types function as named
> constructor functions. There's precedent both in object-oriented languages
> and with Haskell's algebraic data types. Now you can just use this
> expression wherever needed:
> foo(1, 2)
> Thoughts? I'm reluctant to add new incompatibilities with Swift/K, but
> this seems like it would be really clunky otherwise.
> - Tim
> Swift-devel mailing list
> Swift-devel at ci.uchicago.edu
> https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-devel
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20150204/396dd537/attachment.html>
