[Swift-devel] intermediate XML
Michael Wilde
wilde at mcs.anl.gov
Sat Apr 18 00:38:40 CDT 2015
Mihael,
Weren't you at one time looking into using the Swift/T parser for Swift/K?
Or the Swift/T ANTLR grammar?
I thought this was at least mentioned in a Swift team meeting.
- Mike
On Fri, Apr 17, 2015 at 11:31 PM, Tim Armstrong <tim.g.armstrong at gmail.com>
wrote:
> Makes sense to me if it simplifies the code - I'm not sure how much
> ongoing maintenance overhead it is to keep up the additional
> transformations.
> - Tim
> On 17 April 2015 at 22:18, Mihael Hategan <hategan at mcs.anl.gov> wrote:
>> Hi,
>> I think we should remove the intermediate XML (aka. swiftx).
>> It was initially meant to be an abstract representation (like Java
>> bytecode) so that multiple backends could be implemented easily.
>> However, the reality is that the XML is a direct representation of the
>> swift/K parse tree. The other reality is that the only potential place
>> that could have used this as intended (swift/T) didn't.
>> Here's what happens in the code:
>> 1. swift parser parses the .swift code and generates a representation of
>> the parse tree as StringTemplate objects.
>> 2. the StringTemplate tree gets serialized to XML using swiftscript.stg
>> (a template collection). This gets saved to disk.
>> 3. XML beans are generated from the schema and the generated XML is
>> loaded into a tree of XML Beans.
>> 4. The Karajan class traverses the XML Beans tree and generates karajan
>> code (using StringTemplate objects).
>> I think that everything between steps 1 and 4 is just Rube Goldberg
>> code. It translates the same data structure between StringTemplate to
>> XML to XML Beans. It could all (easily I might add) be replaced with
>> nice Java classes representing the parse tree.
>> Opinions?
>> Mihael
>> Swift-devel mailing list
>> Swift-devel at ci.uchicago.edu
>> https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-devel
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20150418/a5e26ff5/attachment.html>
