[Swift-devel] intermediate XML
Tim Armstrong
tim.g.armstrong at gmail.com
Fri Apr 17 23:31:00 CDT 2015
Makes sense to me if it simplifies the code - I'm not sure how much ongoing
maintenance overhead it is to keep up the additional transformations.
- Tim
On 17 April 2015 at 22:18, Mihael Hategan <hategan at mcs.anl.gov> wrote:
> Hi,
> I think we should remove the intermediate XML (aka. swiftx).
> It was initially meant to be an abstract representation (like Java
> bytecode) so that multiple backends could be implemented easily.
> However, the reality is that the XML is a direct representation of the
> swift/K parse tree. The other reality is that the only potential place
> that could have used this as intended (swift/T) didn't.
> Here's what happens in the code:
> 1. swift parser parses the .swift code and generates a representation of
> the parse tree as StringTemplate objects.
> 2. the StringTemplate tree gets serialized to XML using swiftscript.stg
> (a template collection). This gets saved to disk.
> 3. XML beans are generated from the schema and the generated XML is
> loaded into a tree of XML Beans.
> 4. The Karajan class traverses the XML Beans tree and generates karajan
> code (using StringTemplate objects).
> I think that everything between steps 1 and 4 is just Rube Goldberg
> code. It translates the same data structure between StringTemplate to
> XML to XML Beans. It could all (easily I might add) be replaced with
> nice Java classes representing the parse tree.
> Opinions?
> Mihael
> Swift-devel mailing list
> Swift-devel at ci.uchicago.edu
> https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-devel
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20150417/f270fe07/attachment.html>
