[Swift-devel] worker logs
Michael Wilde
wilde at anl.gov
Fri Sep 19 13:57:58 CDT 2014
You can get close-enough data from the main Swift .log file.
- Mike
On 9/19/14, 1:54 PM, Ketan Maheshwari wrote:
> Yes, I know the workers start because in an earlier modification in
> worker.pl <http://worker.pl> I had a syntax error and the error
> message showed up on stderr.
> After, correcting the error, things actually run with provider coaster
> and mode local:cobalt so I assume the workers are running alright.
> With timestamped logs, I want to see if the jobs are spawned at right
> intervals as I intend with these mods.
> On Fri, Sep 19, 2014 at 1:46 PM, Justin M Wozniak <wozniak at mcs.anl.gov
> <mailto:wozniak at mcs.anl.gov>> wrote:
> Are you running workers on the BG/Q compute nodes?
> Are you sure the workers are starting? You may want to put some
> output calls in the start of worker.pl <http://worker.pl> to see
> if they start.
> On 09/19/2014 01:18 PM, Michael Wilde wrote:
>> Perhaps an environment variable (or argument?) to turn on worker
>> logging is not getting through the cobalt provider and/or cobalt
>> to the worker?
>> On 9/19/14, 1:15 PM, Ketan Maheshwari wrote:
>>> Hi,
>>> A question about worker logs with Swift 0.95 automatic coasters:
>>> With these lines in sites.xml:
>>> <profile namespace="globus" key="workerLoggingLevel">DEBUG</profile>
>>> key="workerLoggingDirectory">/tmp/workerlog</profile>
>>> I get worker logs in the said directory for local:local on my
>>> localhost.
>>> However, when trying the same for local:cobalt on BlueGene, I do
>>> not get any worker logs.
>>> Any clues as to what could be the reason for not getting worker
>>> logs on BlueGene? Compute nodes can write to
>>> workerLoggingDirectory so I do not thing it is an issue.
>>> Thanks,
>>> Ketan
>>> _______________________________________________
>>> Swift-devel mailing list
>>> Swift-devel at ci.uchicago.edu <mailto:Swift-devel at ci.uchicago.edu>
>>> https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-devel
>> Michael Wilde
>> Mathematics and Computer Science Computation Institute
>> Argonne National Laboratory The University of Chicago
> Justin M Wozniak
Michael Wilde
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20140919/2d56c5dc/attachment.html>
