[Swift-devel] worker logs
    Ketan Maheshwari
    ketan at mcs.anl.gov
    Fri Sep 19 13:54:06 CDT 2014
Yes, I know the workers start because in an earlier modification in
worker.pl I had a syntax error and the error message showed up on stderr.
After, correcting the error, things actually run with provider coaster and
mode local:cobalt so I assume the workers are running alright. With
timestamped logs, I want to see if the jobs are spawned at right intervals
as I intend with these mods.
On Fri, Sep 19, 2014 at 1:46 PM, Justin M Wozniak <wozniak at mcs.anl.gov>
wrote:
> Are you running workers on the BG/Q compute nodes?
> Are you sure the workers are starting?  You may want to put some output
> calls in the start of worker.pl to see if they start.
> On 09/19/2014 01:18 PM, Michael Wilde wrote:
> Perhaps an environment variable (or argument?) to turn on worker logging
> is not getting through the cobalt provider and/or cobalt to the worker?
> On 9/19/14, 1:15 PM, Ketan Maheshwari wrote:
> Hi,
>  A question about worker logs with Swift 0.95 automatic coasters:
>  With these lines in sites.xml:
>  <profile namespace="globus" key="workerLoggingLevel">DEBUG</profile>
> key="workerLoggingDirectory">/tmp/workerlog</profile>
>  I get worker logs in the said directory for local:local on my localhost.
>  However, when trying the same for local:cobalt on BlueGene, I do not get
> any worker logs.
>  Any clues as to what could be the reason for not getting worker logs on
> BlueGene? Compute nodes can write to workerLoggingDirectory so I do not
> thing it is an issue.
>  Thanks,
> Ketan
> Swift-devel mailing listSwift-devel at ci.uchicago.eduhttps://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-devel
> Michael Wilde
> Mathematics and Computer Science          Computation Institute
> Argonne National Laboratory               The University of Chicago
> Justin M Wozniak
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20140919/46339ae7/attachment.html>
