[Swift-devel] Back to work
    Michael Wilde
    wilde at anl.gov
    Thu May 29 09:32:34 CDT 2014
Tim, this sounds good.  Could you consider how we'd do an async task
executor that can use iPython's parallel-remote services, as an
alternative to coasters?
- Mike
ps. Yadu will return to CI on Mon June 2. He's working remotely this week.
On 5/29/14, 9:18 AM, Tim Armstrong wrote:
> Welcome back Yadu!
> This isn't work for Yadu exactly, but it touches on Yadu's coasters work.
> I was going to flag that I intended to push forward on full integration of
> asynchronous task executors (GeMTC/Coasters/others) into Swift over the
> summer, since it's important but I haven't gotten around to adding proper
> support for multiple worker types, etc:
> https://code.google.com/p/exm-issues/issues/detail?id=581
> https://code.google.com/p/exm-issues/issues/detail?id=503
> https://code.google.com/p/exm-issues/issues/detail?id=609
> - Tim
> On Thu, May 29, 2014 at 9:08 AM, Michael Wilde <wilde at anl.gov> wrote:
>> Hi Yadu, welcome back! (at least, part-way back ;)
>> Hope you're having a very pleasant holiday with family and friends.
>> I'll start steering some work your way.  First thing, can you:
>> a) check on the automated tests and report to me what they are seeing.
>> What should I and others (Mihael, Justin, Tim) be looking at to see how
>> the tests are doing?
>> b) Get tests in place, and extend the tests, to test the new "array
>> return from app" logic:
>> - test with and without provider staging
>> - test with and without location= (and other stages)
>> - test with a variety of mappers, starting with simple_mapper and
>> array_mapper(s)
>> - test with and without returning non-array files along with array files
>> (in combination with the above...)
>>   From the list below, 1-3 is good; please set 4 aside for now.
>> Thanks,
>> - Mike
>> On 5/27/14, 2:41 AM, Yadu Nand wrote:
>>> Hi Mike,
>>> I've been working a couple of hours spread over weeks on pSIMS for some
>>> additional
>>> changes Joshua wanted. I have the hours noted for those.
>>> I'll be working in a bit more regular fashion this week, and we can talk
>> if
>>> needed over skype.
>>> Here's what's on my list:
>>> 1. Fix the image issue with compute-engine and mail the list.
>>>     (My brother is testing this for me)
>>> 2. Documentation for pSIMS.
>>> 3. Get the test-suite to report results better.
>>> 4. Go over the picloud documentation (they've stopped new signups)
>>> If anything of higher priority comes along, I'll be glad to help.
>>> Thanks,
>>> Yadu
>> Michael Wilde
>> Mathematics and Computer Science          Computation Institute
>> Argonne National Laboratory               The University of Chicago
>> Swift-devel mailing list
>> Swift-devel at ci.uchicago.edu
>> https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-devel
Michael Wilde
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20140529/28a375c5/attachment.html>
