[Swift-devel] Swift web changes pending
Mihael Hategan
hategan at mcs.anl.gov
Wed Jun 4 20:25:27 CDT 2014
There's a few of the form "sleep not in tc.data", "unknown site
'beagle'", etc.
There's also a few "could not create JVM", which seem to point to some
problem with the remote environment when starting coasters.
Can you fix those please, so we can get an idea of where there are
actual swift failures?
Mihael
On Thu, 2014-06-05 at 03:43 +0530, Yadu Nand wrote:
> Hi,
> The last tests which ran Swift 0.95 Branch SVN swift-r7871 (swift modified
> locally) cog-r3905 passed most tests.
> There are tests which are failing including a remote testing failure on
> frisbee (mac). Build is working.
> I need to check into the modis test failures, which seem to be config
> issues.
> Here's a link to the results :
> http://swift.rcc.uchicago.edu:8043/swift-0.95/run-2014-06-03-220931/tests-2014-06-03.html
> Links from remote sites:
> Link:
> http://swift.rcc.uchicago.edu:8042/swift-0.95/run-2014-06-03-login4.beagle.ci.uchicago.edu-220931/tests-2014-06-03.html
> Link:
> http://swift.rcc.uchicago.edu:8042/swift-0.95/run-2014-06-03-midway001-220931/tests-2014-06-03.html
> Link:
> http://swift.rcc.uchicago.edu:8042/swift-0.95/run-2014-06-03-thwomp-220931/tests-2014-06-03.html
> Link:
> http://swift.rcc.uchicago.edu:8042/swift-0.95/run-2014-06-03-blogin1-220931/tests-2014-06-03.html
> Link:
> http://swift.rcc.uchicago.edu:8042/swift-0.95/run-2014-06-03-flogin1-220931/tests-2014-06-03.html
> Link:
> http://swift.rcc.uchicago.edu:8042/swift-0.95/run-2014-06-03-communicado.ci.uchicago.edu-220931/tests-2014-06-03.html
> -Yadu
> On Mon, Jun 2, 2014 at 10:53 AM, Mihael Hategan <hategan at mcs.anl.gov> wrote:
> > On Mon, 2014-06-02 at 00:21 -0500, Michael Wilde wrote:
> > > I just pushed these changes live. I had to manually update push_to.sh
> > > (David, is the list of pages supposed to be maintained automatically?
> > > Maybe we can drive that off of a find?)
> > > Mihael just fixed ticket 1279. David will make 0.95 the "latest
> > > download" (and update the button on both Home and Download, as push
> > > 0.94.X to the older releases page)?
> > > Yadu, can you re-test this release when you are back online in Chicago?
> > Yeah, do we have a general feel for 0.95? I lost track.
> > Mihael
> > _______________________________________________
> > Swift-devel mailing list
> > Swift-devel at ci.uchicago.edu
> > https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-devel
