[Swift-devel] Swift web changes pending
    Yadu Nand
    yadudoc1729 at gmail.com
    Wed Jun  4 17:13:01 CDT 2014
The last tests which ran Swift 0.95 Branch SVN swift-r7871 (swift modified
locally) cog-r3905 passed most tests.
There are tests which are failing including a remote testing failure on
frisbee (mac). Build is working.
I need to check into the modis test failures, which seem to be config
issues.
Here's a link to the results :
http://swift.rcc.uchicago.edu:8043/swift-0.95/run-2014-06-03-220931/tests-2014-06-03.html
Links from remote sites:
Link:
http://swift.rcc.uchicago.edu:8042/swift-0.95/run-2014-06-03-login4.beagle.ci.uchicago.edu-220931/tests-2014-06-03.html
Link:
http://swift.rcc.uchicago.edu:8042/swift-0.95/run-2014-06-03-midway001-220931/tests-2014-06-03.html
Link:
http://swift.rcc.uchicago.edu:8042/swift-0.95/run-2014-06-03-thwomp-220931/tests-2014-06-03.html
Link:
http://swift.rcc.uchicago.edu:8042/swift-0.95/run-2014-06-03-blogin1-220931/tests-2014-06-03.html
Link:
http://swift.rcc.uchicago.edu:8042/swift-0.95/run-2014-06-03-flogin1-220931/tests-2014-06-03.html
Link:
http://swift.rcc.uchicago.edu:8042/swift-0.95/run-2014-06-03-communicado.ci.uchicago.edu-220931/tests-2014-06-03.html
-Yadu
On Mon, Jun 2, 2014 at 10:53 AM, Mihael Hategan <hategan at mcs.anl.gov> wrote:
> On Mon, 2014-06-02 at 00:21 -0500, Michael Wilde wrote:
> > I just pushed these changes live.  I had to manually update push_to.sh
> > (David, is the list of pages supposed to be maintained automatically?
> > Maybe we can drive that off of a find?)
> > Mihael just fixed ticket 1279. David will make 0.95 the "latest
> > download" (and update the button on both Home and Download, as push
> > 0.94.X to the older releases page)?
> > Yadu, can you re-test this release when you are back online in Chicago?
> Yeah, do we have a general feel for 0.95? I lost track.
> Mihael
> Swift-devel mailing list
> Swift-devel at ci.uchicago.edu
> https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-devel
Yadu Nand B
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20140605/47701b3a/attachment.html>
