[Swift-devel] Notes from trying new config
    Tim Armstrong
    tim.g.armstrong at gmail.com
    Thu Jul 24 22:13:30 CDT 2014
I don't think I saw one.
- Tim
On Thu, Jul 24, 2014 at 6:36 PM, Mihael Hategan <hategan at mcs.anl.gov> wrote:
> Was there ever a reply from me on this? I have one in my "Sent" folder,
> but I don't see it on the mailing list.
> Mihael
> On Wed, 2014-07-16 at 17:36 -0500, Yadu Nand Babuji wrote:
> > Hi
> > I just tried to run some test scripts using trunk and these are my
> > observations:
> > I copied the swift.conf file from the configuration section in the trunk
> > userguide.
> > 1. I got an error about lazy.errors=false. Found that lazy.errors has
> > been replaces by lazyErrors. Minor doc mismatch here.
> > 2. Then I got a swift.conf:2 missing mandatory property
> > 'site.local.workDirectory'
> > 3. Then this -> swift.conf:2 missing mandatory property
> > 'site.local.filesystem.type'
> >      - This one is missing documentation as well.
> > I like that there are sensible error messages, but at the same time I
> > feel that the config file has gotten a bit more verbose
> > that the 0.95 swift.properties. I really like the 0.95 feature where you
> > could have several sites defined in your config file, and
> > then you choose what sites to run on from the commandline using
> > -sites=<sites1, ...>. This makes the commandline very
> > simple and helps with tutorials and demos.
> > I could not get past this error once it looked like the config was fixed.
> > swift -config swift.conf sanity.swift
> > Swift trunk swift-r8021 cog-r4025 (cog modified locally)
> > RunID: run014
> > Could not start execution:
> >      Import of 'swift.k' failed, import @ sanity.kml, line: 5:
> >      Invalid node definition class:
> > org.griphyn.vdl.karajan.lib.Mapping$Cons, def @ swift.k, line: 91:
> > -Yadu
> Swift-devel mailing list
> Swift-devel at ci.uchicago.edu
> https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-devel
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20140724/a3ddeee1/attachment.html>
