[Swift-devel] Issues to resolve for the 0.96 config mechanism
Yadu Nand Babuji yadunand at uchicago.edu
Wed Jul 16 01:17:39 CDT 2014
Hi Mihael,
Does the new config allow you to specify multiple sites in the
swift.conf and select the site you want to run on from the swift
commandline.
I searched the swift-trunk userguide, but did not see any reference to this.
The 0.95 tutorials, which I think are the cleanest our tutorials have
been, let you select the site(s) you want to run on and the
swift.properties sets a default site(s) to use in case no commandline
option is given for site
swift.properties:
# default site is local
site=local
site.beagle-remote {
site.local {
Yadu
On 07/16/2014 01:04 AM, Mihael Hategan wrote:
> Hi,
> I'll be in New York for the remainder of the week and returning Monday
> (21st). I might sporadically work on this, but in all likelihood commits
> will come after that. However, I wanted so sync on the latest spec:
> * releaseConf=$SWIFT_HOME/etc/swift.conf
> siteConf=$SWIFT_SITE_CONF (if $SWIFT_SITE_CONF defined)
> userConf=$HOME/.swift/swift.conf (if present)
> runConf=$PWD/swift.conf (if present)
> -config
> * The configs should be chained automatically.
> * Documentation updated, in particular copying and updating the 0.95
> section on the search path and documenting swift-convert-config and how
> to migrate from pre-0.95 files. The tool should also be updated to
> accept and convert 0.95 configs.
> * -noReleaseConf, -noSiteConf, -noUserConf, -noRunConf command-line
> flags to be added. Please comment on the equivalent properties and the
> difficulty in implementing them. If you feel it's important, it might be
> worth conquering those difficulties.
> * line numbers for properties in -listconfig and log.
> Things that might still merit some discussion:
> * -listconfig <files|full> (this is a proposal to add a parameter to
> -listconfig that specifies whether only a list of files or a list of
> files and all options should be printed).
> * Also please comment on the -config file vs. -config file1:file2... and
> the need for -reconfig. I can't quite tell whether these were meant to
> be discussed or not, and if yes, where we are with that.
> - another question is whether we want properties (in -listconfig and
> log) to be printed as a flat set of dotted properties or grouped. In
> other words:
> site.one.workDirectory = ..
> site.one.staging = ...
> or
> site.one {
>    workDirectory = ...
>    staging = ...
> Mihael
> Swift-devel mailing list
> Swift-devel at ci.uchicago.edu
> https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-devel
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20140716/ac752633/attachment.html>
