[Swift-devel] Issues to resolve for the 0.96 config mechanism
Mihael Hategan
hategan at mcs.anl.gov
Sun Jul 13 13:01:19 CDT 2014
On Sun, 2014-07-13 at 11:01 -0500, Michael Wilde wrote:
> - default property file names have changed: swift.properties vs swift.config
On purpose, to avoid left-overs from being confusing.
> - the search path implemented by 0.95 is (I suspect) not yet carried
> forward here, and that needs discussion. My inclination is that it
> should be.
> - the include mechanism is new. I think its nice and likely is very
> useful, but I wonder how it will interact with or supplement the
> property search path.
We discussed this a few days ago. We had repeated issues with magically
loaded files from strange locations that the users took a long time to
find and fix. The solution that I saw in 0.95 was even more search
locations, which I think was not right.
So the philosophy in trunk is "either it stares at you or it isn't
there". And includes do this in a way that doesn't sacrifice
convenience.
> Did that come from the underlying config classes used, or was that done
> from scratch? We should also consider hos this works with respect to the
> use of cpp in stc, if we see ourselves heading to the use of stc as a
> universal front end for the Swift toolchain.
> - as we discussed before, but never resolved - we should decide if the
> documented/encouraged format will have colon separators and quoted
> string values.
You need to quote values that have special characters, such as "-" or
spaces, etc. Having to think about whether a particular string or not
does contain "special characters" to see if you are going to write
quotes or not is an effort that I do not think we should push the users
into. But it's a choice.
> I prefer the visually simpler format without either, and
> I think 0.95 also allows an optional "=" separator as in standard
> properties files. ( http://en.wikipedia.org/wiki/.properties is a nice
> summary, and says " Several formats are possible for each line,
> including key=value, key = value, key:value, and key value.")
Give it some time :)
You might like it. I know it's not exactly the 0.95 config. It's not a
perfect world.
> I think we can work all these issues out as we go. I'm eager to test
> trunk in its current state before we address any of the issues above.
> Lets concentrate first on manual testing and on getting the property
> names stabilized and the more important semantic changes.
Right.
> Also, we need to work out issues in application location specifications
> that were started but not yet fully developed in the 0.95 effort. David
> and I discussed these, and we need to capture and post the
> recommendations that were still in progress for this.
Yes, please! I really wished I had seen a discussion on the 0.95 config
before it went into code.
Mihael
