[Swift-devel] Issues to resolve for the 0.96 config mechanism
Michael Wilde
wilde at anl.gov
Sun Jul 13 11:01:15 CDT 2014
I did a quick scan of the new User Guide text that describes the
proposed 0.96 config conventions.
I feel we need to re-examine the mechanism for backwards compatibility
with 0.95, and decide on a few things.
- default property file names have changed: swift.properties vs swift.config
- the search path implemented by 0.95 is (I suspect) not yet carried
forward here, and that needs discussion. My inclination is that it
should be.
- the include mechanism is new. I think its nice and likely is very
useful, but I wonder how it will interact with or supplement the
property search path.
Did that come from the underlying config classes used, or was that done
from scratch? We should also consider hos this works with respect to the
use of cpp in stc, if we see ourselves heading to the use of stc as a
universal front end for the Swift toolchain.
- as we discussed before, but never resolved - we should decide if the
documented/encouraged format will have colon separators and quoted
string values. I prefer the visually simpler format without either, and
I think 0.95 also allows an optional "=" separator as in standard
properties files. ( http://en.wikipedia.org/wiki/.properties is a nice
summary, and says " Several formats are possible for each line,
including key=value, key = value, key:value, and key value.")
I think we can work all these issues out as we go. I'm eager to test
trunk in its current state before we address any of the issues above.
Lets concentrate first on manual testing and on getting the property
names stabilized and the more important semantic changes.
Also, we need to work out issues in application location specifications
that were started but not yet fully developed in the 0.95 effort. David
and I discussed these, and we need to capture and post the
recommendations that were still in progress for this.
- Mike
Michael Wilde
Mathematics and Computer Science Computation Institute
Argonne National Laboratory The University of Chicago
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20140713/7822c921/attachment.html>
