[Swift-devel] some details about softimage
Yadu Nand B yadunand at uchicago.edu
Tue Feb 11 18:29:59 CST 2014
Hi Mihael,
Does this mechanism work with provider-staging and via passive
persistent coasters ?
Since you specify the <dest_dir>, does this mechanism ensure that an
installation happens
only once per node ? Do other workers on the same node wait till the
first worker finishes
the installation ?
I don't see this in the user-guide. Once I get this tested, I'll could
add a doc piece if that helps.
Yadu
On 12/10/2013 04:07 PM, Mihael Hategan wrote:
> Mike asked for some details of how that works.
> You specify it like this in sites.xml:
> <profile namespace="globus"
> key="softImage">/lustre/beagle/hategan/softimg.tar.gz /tmp/softimage</profile>
> That is <tar.gz_location><space><dest_dir>.
> If your tar.gz contains a "start" executable in the root directory, it
> will be executed after unpacking.
> Similarly, if the tar.gz contains a "stop" executable in the root
> directory, it will be executed before cleanup (which is when no more
> jobs will be run on that node).
> Mihael
> Swift-devel mailing list
> Swift-devel at ci.uchicago.edu
> https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-devel
