[Swift-devel] some details about softimage
Mihael Hategan
hategan at mcs.anl.gov
Tue Feb 11 18:48:02 CST 2014
On Tue, 2014-02-11 at 18:29 -0600, Yadu Nand B wrote:
> Hi Mihael,
> Does this mechanism work with provider-staging and via passive
> persistent coasters ?
It's independent of how the coaster service is started, so yes.
> Since you specify the <dest_dir>, does this mechanism ensure that an
> installation happens
> only once per node ?
Of course.
It is, however, deleted when the last worker on a node quits.
> Do other workers on the same node wait till the
> first worker finishes
> the installation ?
Yes.
> I don't see this in the user-guide. Once I get this tested, I'll could
> add a doc piece if that helps.
It probably would help.
Mihael
