[Swift-devel] Tryswift enhancements
    Michael Wilde
    wilde at anl.gov
    Wed Apr 16 10:38:29 CDT 2014
For the progress output:
Swift trunk swift-r7139 cog-r3806
RunID: 20140416-1029-alqxvvi1
Progress:  time: Wed, 16 Apr 2014 10:29:54 -0500
Progress:  time: Wed, 16 Apr 2014 10:29:55 -0500  Selecting site:7  Active:3
Progress:  time: Wed, 16 Apr 2014 10:29:56 -0500  Selecting site:7  Active:3  Finished successfully:3
Progress:  time: Wed, 16 Apr 2014 10:29:57 -0500  Selecting site:7  Active:3  Finished successfully:6
Progress:  time: Wed, 16 Apr 2014 10:29:58 -0500  Selecting site:7  Active:3  Finished successfully:9
- start with Swift run starting at 10:23:03
- suppress Swift version # and RunID lines
- change: Progress:  time: Wed, 16 Apr 2014 10:29:58 -0500  Selecting site:7  Active:3  Finished successfully:9
   to:  10:29:58   Ready:7   Active:3  Done:9  [Failed: 3] (show failures only if non-zero)
Use spaces to make these line up "nicely"
- add a line saying Swift run completed at 10:24:59
Mike
On 4/15/14, 11:32 PM, Michael Wilde wrote:
> David, just to clarify: by the [Explain] notation below I just meant
> to make "Explain" a "button".
> - Mike
> On 4/15/14, 3:56 PM, Michael Wilde wrote:
>> [Moving discussion to swift-devel]
>> On 4/15/14, 12:06 PM, David Kelly wrote:
>>> Hi Mike,
>>> One idea I had for tryswift was to change the way that file outputs
>>> are displayed. Keeping them in a drop down list saves some space and
>>> I think makes it look a little cleaner. To see what I mean, check
>>> out http://swiftvm4.ci.uchicago.edu and try the foreach example
>>> (still working on some CSS changes there as well).
>>> Right now it only handles html/text, but if the file output was
>>> images or videos, they could be loaded in the same window. Just
>>> wanted to get your initial thoughts before I did too much with it.
>> Hi David,
>> I think this is heading in a nice direction. It looks very nice and
>> clean.
>> Some thoughts:
>> Top window:
>> - Add text in front of menu:   Example: [example-menu] [Explain]
>> - [Explain] button should pop out in a new window, sized and placed
>> "nicely" (not quite sure what nicely involves yet ;)
>> Bottom window
>> - its hard to tell when the script completes or how many files it
>> produced
>> - when you view a file it overwrites the progress window
>> - (reset is broken, btw)
>> How about:
>> - dont show the output-files menu while the script is running
>> - when script completes, show the menu with a label [N files
>> produced:] [output-files-menu]
>> - when you select a file, show it in a new popup window "placed
>> nicely" with a [close] button top and bottom
>> - allowing that window to be multi-media sounds nice
>> Bigger project:
>> - for status, show running tally of the status to the right of the
>> control buttons
>> - add button [Progress log] that shows the progress to date or after
>> the fact, as a pop-up. With cleaner timestamp etc. WHich we should
>> make the default for all Swift runs.
>> So with this improved progress menu, you'd have a very clean look
>> with the Swift text taking most of the window, bracketd by a
>> script-selector stripe at the top and an execution control strip at
>> the bottom.
>> How do these sound to you?
>> - Mike
Michael Wilde
Mathematics and Computer Science          Computation Institute
Argonne National Laboratory               The University of Chicago
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20140416/cf928d42/attachment.html>
