[Swift-devel] ssh-cl how to tell coaster bootstrap to run with	limited java heap space
    Ketan Maheshwari
    ketancmaheshwari at gmail.com
    Thu Sep 19 15:43:10 CDT 2013
SDSC Gordon admins have limited java heap space to 256 on login nodes.
This is enabled via the following environment variable:
JAVA_TOOL_OPTIONS=-Xmx256m
It seems coaster bootstrap does not like this:
mdw$ swift -sites.file sites.gordon.xml -tc.file apps -config cf
workflow.swift
Swift trunk swift-r7089 cog-r3775
RunID: 20130919-2038-jef0ns83
Progress:  time: Thu, 19 Sep 2013 20:38:42 +0000
Progress:  time: Thu, 19 Sep 2013 20:38:43 +0000  Submitting:2
Execution failed:
Exception in matrixgen:
    Arguments: [2544, 3300, mA.dat]
    Host: gordon
    Directory: workflow-20130919-2038-jef0ns83/jobs/a/matrixgen-a1rnkhfl
    exception @ swift-int-staging.k, line: 162
Caused by: null
Caused by:
org.globus.cog.abstraction.impl.common.task.TaskSubmissionException: Could
not submit job
Caused by:
not start coaster service
Caused by:
org.globus.cog.abstraction.impl.common.task.TaskSubmissionException: Task
ended before registration was received.
Picked up JAVA_TOOL_OPTIONS: -Xmx256m
/bin/bash: line 54: 33675 Aborted                 /usr/java/latest/bin/java
-Djava=/usr/java/latest/bin/java -DGLOBUS_TCP_PORT_RANGE=50000,51000
-DX509_USER_PROXY=/home/ketan/.globus/sshproxy-316831905-1379663604
-DX509_CERT_DIR=/home/ketan/.globus/sshCAcert-316831905-1379663604.pem
-DGLOBUS_HOSTNAME=gordon.sdsc.xsede.org -Duser.home=/home/ketan -jar
/tmp/bootstrap.RWIqFu http://swift.rcc.uchicago.edu:50001
https://128.135.112.73:50000 11836079986
Do I understand right that this is indeed the java heap space issue? or is
it something else that I could work around with? Thanks for any ideas.
Ketan
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20130919/de5d36e3/attachment.html>
