[Swift-devel] Use wrapper staging parameter in Trunk required?
Mihael Hategan
hategan at mcs.anl.gov
Mon Sep 16 16:52:21 CDT 2013
There was a commit to validate configuration settings. This is a
consequence of that and the fact that there is no default value for this
setting.
I added a default value in r7073.
Mihael
On Mon, 2013-09-16 at 16:29 -0500, Yadu Nand wrote:
> Hi,
> In 0.94 the config used by tests do not specify the line
> use.wrapper.staging in the
> config file and they pass.The same tests on trunk fail with the error
> pasted here ->
> [yadunand at midway001 x_append_iter-142706]$ swift -tc.file tc.data
> -sites.file sites.xml -config swift.properties x_append_iter.swift
> Swift trunk swift-r7071 (swift modified locally) cog-r3787 (cog modified
> locally)
> RunID: 20130916-2120-ovvu8v0g
> Could not start execution:
> Import of 'swift.k' failed:
> Swift config property "use.wrapper.staging" not found in Swift
> configuration ([swift.properties]): {throttle.score.job.factor=4,
> throttle.file.operations=8, throttle.host.submit=2,
> pgraph.node.options=color="seagreen", style="filled",
> wrapper.parameter.mode=args, provenance.log=false, throttle.submit=4,
> ticker.prefix=Progress: time:, provider.staging.pin.swiftfiles=false,
> clustering.enabled=false, replication.min.queue.time=60,
> sites.file=sites.xml, cdm.broadcast.mode=file, kickstart.enabled=maybe,
> wrapperlog.always.transfer=true, caching.algorithm=LRU,
> use.provider.staging=false, status.mode=provider, clustering.min.time=60,
> ticker.date.format=, kickstart.always.transfer=false, file.gc.enabled=true,
> throttle.transfers=4, execution.retries=0, sitedir.keep=true,
> pgraph.graph.options=splines="compound", rankdir="TB",
> replication.enabled=false, clustering.queue.delay=4, pgraph=false,
> mapping.checker=on, wrapper.invocation.mode=absolute, tc.file=tc.data,
> replication.limit=3, lazy.errors=false}:
> Is this expected behavior ?
> Hi,
> pasted here ->
> modified locally)
> kickstart.enabled=maybe, wrapperlog.always.transfer=true,
> caching.algorithm=LRU, use.provider.staging=false,
> status.mode=provider, clustering.min.time=60, ticker.date.format=,
> Yadu Nand B
> Swift-devel mailing list
> Swift-devel at ci.uchicago.edu
> https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-devel
