[Swift-devel] Use wrapper staging parameter in Trunk required?
    Yadu Nand
    yadudoc1729 at gmail.com
    Mon Sep 16 16:29:13 CDT 2013
In 0.94 the config used by tests do not specify the line
use.wrapper.staging in the
config file and they pass.The same tests on trunk fail with the error
pasted here ->
[yadunand at midway001 x_append_iter-142706]$ swift -tc.file tc.data
-sites.file sites.xml -config swift.properties x_append_iter.swift
Swift trunk swift-r7071 (swift modified locally) cog-r3787 (cog modified
locally)
RunID: 20130916-2120-ovvu8v0g
Could not start execution:
Import of 'swift.k' failed:
 Swift config property "use.wrapper.staging" not found in Swift
configuration ([swift.properties]): {throttle.score.job.factor=4,
throttle.file.operations=8, throttle.host.submit=2,
pgraph.node.options=color="seagreen", style="filled",
wrapper.parameter.mode=args, provenance.log=false, throttle.submit=4,
ticker.prefix=Progress:  time:, provider.staging.pin.swiftfiles=false,
clustering.enabled=false, replication.min.queue.time=60,
sites.file=sites.xml, cdm.broadcast.mode=file, kickstart.enabled=maybe,
wrapperlog.always.transfer=true, caching.algorithm=LRU,
use.provider.staging=false, status.mode=provider, clustering.min.time=60,
ticker.date.format=, kickstart.always.transfer=false, file.gc.enabled=true,
throttle.transfers=4, execution.retries=0, sitedir.keep=true,
pgraph.graph.options=splines="compound", rankdir="TB",
replication.enabled=false, clustering.queue.delay=4, pgraph=false,
mapping.checker=on, wrapper.invocation.mode=absolute, tc.file=tc.data,
replication.limit=3, lazy.errors=false}:
Is this expected behavior ?
Yadu Nand B
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20130916/7d117ac2/attachment.html>
