[Swift-devel] MODIS freezes on Midway
Ketan Maheshwari ketancmaheshwari at gmail.com
Tue Mar 19 18:04:44 CDT 2013
In addition to what David mentioned, from logs, it seems that your sites
file is missing this line:
<filesystem provider="local"/>
Or David, correct me if this is not required in this configuration.
On Tue, Mar 19, 2013 at 6:00 PM, David Kelly <davidk at ci.uchicago.edu> wrote:
> Yadu,
> The setup.sh script sets this environment variable:
> export SBATCH_RESERVATION=osg
> I believe sbatch is picking up on this and trying to run with this
> reservation, which is likely expired. Can you try unsetting
> SBATCH_RESERVATION, commenting out that line in setup.sh and trying again?
> Thanks,
> David
> *From: *"Yadu Nand" <yadudoc1729 at gmail.com>
> *To: *"swift-devel" <swift-devel at ci.uchicago.edu>
> *Sent: *Tuesday, March 19, 2013 5:35:41 PM
> *Subject: *[Swift-devel] MODIS freezes on Midway
> Hi,
> I've been running the modis tests on Midway, from the demo that mike had
> shared:
> /home/wilde/osgdemo/modis/svn/swiftdemo.v04.tgz
> In the logs(please see attachment) I see a fail message :  "sbatch:
> error: Batch job
> submission failed: Requested reservation is invalid"
> The fact that no error messages are shown on stdout doesn't help, plus,
> swift just
> seems to hang forever. * Please help! *
> I see test.midway show no progress, with just the same status for about
> 20mins:
> Progress:  time: Tue, 19 Mar 2013 20:21:18 +0000  Selecting site:35
>  Submitted:65
> After this, I tried to kill by Ctrl+C and then I get a few error messages :
> Failed to shut down block: Block 0319-5807480-000000 (16x3540.000s)
> org.globus.cog.abstraction.impl.common.task.TaskSubmissionException: Can
> only cancel an active task
> at
> org.globus.cog.abstraction.impl.scheduler.common.AbstractExecutor.cancel(AbstractExecutor.java:196)
>  at
> org.globus.cog.abstraction.impl.scheduler.common.AbstractJobSubmissionTaskHandler.cancel(AbstractJobSubmissionTaskHandler.java:85)
> at
> org.globus.cog.abstraction.impl.common.AbstractTaskHandler.cancel(AbstractTaskHandler.java:69)
>  at
> org.globus.cog.abstraction.impl.common.task.ExecutionTaskHandler.cancel(ExecutionTaskHandler.java:106)
> at
> org.globus.cog.abstraction.impl.common.task.ExecutionTaskHandler.cancel(ExecutionTaskHandler.java:95)
>  at
> org.globus.cog.abstraction.coaster.service.job.manager.BlockTaskSubmitter.cancel(BlockTaskSubmitter.java:46)
> at
> org.globus.cog.abstraction.coaster.service.job.manager.Block.forceShutdown(Block.java:332)
>  at
> org.globus.cog.abstraction.coaster.service.job.manager.Block.shutdown(Block.java:312)
> at
> org.globus.cog.abstraction.coaster.service.job.manager.BlockQueueProcessor.shutdownBlocks(BlockQueueProcessor.java:800)
>  at
> org.globus.cog.abstraction.coaster.service.job.manager.BlockQueueProcessor.shutdown(BlockQueueProcessor.java:789)
> at
> org.globus.cog.abstraction.coaster.service.job.manager.JobQueue.shutdown(JobQueue.java:119)
>  at
> org.globus.cog.abstraction.coaster.service.CoasterService.shutdown(CoasterService.java:271)
> at
> org.globus.cog.abstraction.coaster.service.ServiceShutdownHandler.requestComplete(ServiceShutdownHandler.java:28)
>  at
> org.globus.cog.karajan.workflow.service.handlers.RequestHandler.receiveCompleted(RequestHandler.java:88)
> at
> org.globus.cog.karajan.workflow.service.channels.AbstractKarajanChannel.handleRequest(AbstractKarajanChannel.java:519)
>  at
> org.globus.cog.karajan.workflow.service.channels.AbstractPipedChannel.actualSend(AbstractPipedChannel.java:86)
> at
> org.globus.cog.karajan.workflow.service.channels.AbstractPipedChannel$Sender.run(AbstractPipedChannel.java:115)
> Yadu Nand B
> Swift-devel mailing list
> Swift-devel at ci.uchicago.edu
> https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-devel
Ketan
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20130319/9d6a3b6d/attachment.html>
