[Swift-devel] Please help: error "
    Michael Wilde
    wilde at mcs.anl.gov
    Sat Jun 15 19:06:49 CDT 2013
Wonderful, that fixes it - thanks very much!
Justin, my swift on midway is now updated with this fix, and is the best Swift to use there for Sundays demos.
$ cat ./set-swift
PATH=/project/wilde/swift/src/0.94/cog/modules/swift/dist/swift-svn/bin:$PATH
- Mike
----- Original Message -----
> From: "Mihael Hategan" <hategan at mcs.anl.gov>
> To: "Michael Wilde" <wilde at mcs.anl.gov>
> Cc: "Swift Devel" <swift-devel at ci.uchicago.edu>, "David Kelly" <davidk at ci.uchicago.edu>
> Sent: Saturday, June 15, 2013 6:49:32 PM
> Subject: Re: [Swift-devel] Please help: error "
> This should now be fixed in SVN. Thanks David for the hint about the
> coaster service change being at the root of the problem.
> Mihael
> On Sat, 2013-06-15 at 08:58 -0500, Michael Wilde wrote:
> > I sent this help request because I thought it was causing the demo
> > runs to fail.
> > When David tested, he noted that the error was *not* causing any
> > failures.
> > Testing now, I too see that the demo now seems to be working.
> > Its possible that I was misled by some other aspect of the run(s) I
> > did.
> > So we should fix this, and verify what the impact is, but for now I
> > *think* its OK.
> > My command line, output, dir on midway, and sites.xml is below.
> > The log for this runs is at
> > http://www.ci.uchicago.edu/~wilde/atlas01-20130615-1355-z6imink0.log
> > Thanks,
> > - Mike
> > swift$ swift -tc.file apps.midway -sites.file t.xml atlas01.swift
> > Swift 0.94 swift-r6549 cog-r3672 (cog modified locally)
> > RunID: 20130615-1355-z6imink0
> > Progress:  time: Sat, 15 Jun 2013 13:55:47 +0000
> > Failed to configure log file name
> > Progress:  time: Sat, 15 Jun 2013 13:55:52 +0000  Stage in:1
> >  Submitted:3
> > Progress:  time: Sat, 15 Jun 2013 13:55:53 +0000  Stage in:3
> >  Active:1
> > Final status: Sat, 15 Jun 2013 13:55:54 +0000  Finished
> > successfully:4
> > swift$ pwd
> > /home/wilde/Projects/OHBM2013/svn-mcs
> > swift$ cat t.xml
> > <config>
> >   <pool handle="localhost">
> >     <execution provider="local"/>
> >     <profile namespace="karajan" key="initialScore">10000</profile>
> >     <filesystem provider="local"/>
> >     <workdirectory>/scratch/midway/{env.USER}/swiftwork</workdirectory>
> >     <profile namespace="swift" key="stagingMethod">file</profile>
> >     <profile namespace="karajan" key="jobThrottle">.03</profile>
> >     <!-- eg .11 -> 12 -->
> >   </pool>
> >   <pool handle="midway">
> >     <execution provider="coaster" jobmanager="local:slurm"/>
> >     <!-- Set partition and account here: -->
> >     <profile namespace="globus" key="queue">westmere</profile>
> >     <profile namespace="globus" key="ppn">12</profile>
> >     <!-- <profile namespace="globus"
> >     key="project">pi-wilde</profile> -->
> >     <!-- Set number of jobs and nodes per job here: -->
> >     <profile namespace="globus" key="slots">1</profile>
> >     <profile namespace="globus" key="maxnodes">1</profile>
> >     <profile namespace="globus" key="nodegranularity">1</profile>
> >     <profile namespace="globus" key="jobsPerNode">12</profile> <!--
> >     apps per node! -->
> >     <profile namespace="karajan" key="jobThrottle">.11</profile>
> >     <!-- Set estimated app time (maxwalltime) and requested job
> >     time (maxtime) here: -->
> >     key="maxWalltime">00:15:00</profile>
> >     <profile namespace="globus" key="maxtime">1800</profile>  <!--
> >     in seconds! -->
> >     <!-- Set data staging model and work dir here: -->
> >     <!-- Typically leave these constant: -->
> >     key="slurm.exclusive">false</profile>
> >     key="highOverAllocation">100</profile>
> >     key="lowOverAllocation">100</profile>
> >   </pool>
> > </config>
> > swift$
> > > To: "David Kelly" <davidk at ci.uchicago.edu>
> > > Cc: "Swift Devel" <swift-devel at ci.uchicago.edu>, "Michael Wilde"
> > > Sent: Saturday, June 15, 2013 3:47:04 AM
> > > The change you mention was meant to re-name the coaster log file
> > > to
> > > something containing the date rather than just coasters.log.
> > > It did just occur to me that this might happen when using coaster
> > > local:x. Is that what's happening? In other words, what's in
> > > sites.xml
> > > for the run that prints this error?
> > > Mihael
> > > PS: the run should just continue and there should be no stack
> > > trace
> > > (as
> > > David points out).
> > > On Fri, 2013-06-14 at 16:36 -0500, David Kelly wrote:
> > > > I think this is related to some changes in CoasterService.java
> > > > last
> > > > week. A version of Swift from a few weeks ago with the same
> > > > scripts/setup doesn't produce this message. Swift seems to
> > > > continue
> > > > running after this, and I don't see a stack trace.
> > > > > Sent: Friday, June 14, 2013 4:28:56 PM
> > > > > Probably a custom log4j in your classpath that does not have
> > > > > a
> > > > > file
> > > > > appender.
> > > > > Is there a stack trace?
> > > > > Mihael
> > > > > On Fri, 2013-06-14 at 14:57 -0500, Michael Wilde wrote:
> > > > > > Hi All,
> > > > > > Can anyone help me find the cause of the error below:
> > > > > > "Failed
> > > > > > to
> > > > > > configure log file name"
> > > > > > Ive never seen this before.
> > > > > > Im getting it on midway: swift.rcc.uchicago.edu, dir
> > > > > > /home/wilde/Projects/OHBM2013/svn:
> > > > > > swift$ swift -config swift.properties -tc.file apps.midway
> > > > > > genatlas.swift -d=data_2
> > > > > > RunID: 20130614-1954-66k4nvfe
> > > > > > Progress: time: Fri, 14 Jun 2013 19:55:01 +0000
> > > > > > Thanks!
> > > > > > - Mike
> > > > > > _______________________________________________
> > > > > > Swift-devel mailing list
> > > > > > Swift-devel at ci.uchicago.edu
> > > > > > https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-devel
> > > > last
> > > > continue
> > > > ______________________________________________________________________
> > > >         have a
> > > >         file
> > > >         appender.
> > > >         Mihael
> > > >         > Hi All,
> > > >         "Failed to configure log file name"
> > > >         dir /home/wilde/Projects/OHBM2013/svn:
> > > >         > apps.midway
> > > >         > locally)
> > > >         > Thanks!
> > > >         > - Mike
