[Swift-devel] Please help: error "
    Mihael Hategan
    hategan at mcs.anl.gov
    Sat Jun 15 03:47:04 CDT 2013
The change you mention was meant to re-name the coaster log file to
something containing the date rather than just coasters.log.
It did just occur to me that this might happen when using coaster
local:x. Is that what's happening? In other words, what's in sites.xml
for the run that prints this error?
Mihael
PS: the run should just continue and there should be no stack trace (as
David points out).
On Fri, 2013-06-14 at 16:36 -0500, David Kelly wrote:
> I think this is related to some changes in CoasterService.java last
> week. A version of Swift from a few weeks ago with the same
> scripts/setup doesn't produce this message. Swift seems to continue
> running after this, and I don't see a stack trace.
> > From: "Mihael Hategan" <hategan at mcs.anl.gov>
> > To: "Michael Wilde" <wilde at mcs.anl.gov>
> > Cc: "Swift Devel" <swift-devel at ci.uchicago.edu>
> > Sent: Friday, June 14, 2013 4:28:56 PM
> > Subject: Re: [Swift-devel] Please help: error "
> > Probably a custom log4j in your classpath that does not have a file
> > appender.
> > Is there a stack trace?
> > Mihael
> > On Fri, 2013-06-14 at 14:57 -0500, Michael Wilde wrote:
> > > Hi All,
> > > Can anyone help me find the cause of the error below: "Failed to
> > > configure log file name"
> > > Ive never seen this before.
> > > Im getting it on midway: swift.rcc.uchicago.edu, dir
> > > /home/wilde/Projects/OHBM2013/svn:
> > > swift$ swift -config swift.properties -tc.file apps.midway
> > > genatlas.swift -d=data_2
> > > Swift 0.94 swift-r6549 cog-r3672 (cog modified locally)
> > > RunID: 20130614-1954-66k4nvfe
> > > Progress: time: Fri, 14 Jun 2013 19:55:01 +0000
> > > Failed to configure log file name
> > > Thanks!
> > > - Mike
> > > _______________________________________________
> > > Swift-devel mailing list
> > > Swift-devel at ci.uchicago.edu
> > > https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-devel
> ______________________________________________________________________
>         file
>         appender.
>         Mihael
>         > Hi All,
>         "Failed to configure log file name"
>         dir /home/wilde/Projects/OHBM2013/svn:
>         > Thanks!
>         > - Mike
