[Swift-devel] Status of ssh data provider tests
David Kelly davidk at ci.uchicago.edu
Tue Jun 11 07:41:38 CDT 2013
Yadu,
I added a siteguide entry that gives the steps for setting up a run with the ssh provider. It's at http://www.ci.uchicago.edu/swift/guides/release-0.94/siteguide/siteguide.html#_ssh. I tested this from Midway to Beagle. The only difference is that on Beagle, $HOME/.ssh/authorized_keys is read only. When you get to that step, log on to accounts.ci.uchicago.edu and add your new SSH key there. That will update your authorized_keys file (takes a few minutes). I've only tested staging with a single small text file so far. Please let me know if you run into any problems.
David
----- Original Message -----
> From: "David Kelly" <davidk at ci.uchicago.edu>
> To: "Michael Wilde" <wilde at mcs.anl.gov>
> Cc: "Yadu Nand B" <yadunandb at ci.uchicago.edu>, "Swift Devel"
> <swift-devel at ci.uchicago.edu>
> Sent: Monday, June 10, 2013 12:47:14 PM
> Subject: Re: [Swift-devel] Status of ssh data provider tests
> The data staging is the more difficult of the two. There are four
> options I can think of to get around the coaster provider staging
> issue.
> a. Use the ssh provider instead of ssh-cl and set filesystem to ssh.
> This requires setting up an auth.defaults with a stored password or
> passphrase (to avoid being prompted)
> b. Use the ssh provider and the built-in gridftp. Anything that uses
> gridftp obviously requires the usual steps of setting up grid
> certificates.
> c. Use ssh-cl and built-in gsiftp together. I think option is
> impossible due to the way certificates currently work. ssh-cl will
> create it's own certificate for coaster security, so if you have
> X509* defined I don't think things will work.
> d. Try to get things working with wrapper staging. It's possible, but
> will take more time, discussion, and testing.
> Is the need to set up auth.defaults a deal breaker for this?
> > From: "Michael Wilde" <wilde at mcs.anl.gov>
> > To: "David Kelly" <davidk at ci.uchicago.edu>
> > Cc: "Swift Devel" <swift-devel at ci.uchicago.edu>
> > Sent: Monday, June 10, 2013 10:55:54 AM
> > Subject: Status of ssh data provider tests
> > Hi David,
> > Yadu neesd assistance with the following, for the ex-search app:
> > 1. To run from swift.rcc to Beagle using either ssh data staging or
> > gsiftp data staging.
> > (I would like to also use this for two demo/tutorials that we're
> > developing this week for Sunday and Monday presentation.)
> > Can you work with Yadu to test these and verify that Yadu can
> > replicate the results.
> > 2. To apply cdm direct mode for the swift.rcc-to-midway part of the
> > ex-search app. I think we showed how to do this in the last Swift
> > RCC tutorial. Can you help Yadu to locate that (or create from
> > scratch if no), test it, and integrate it into the ex-search app?
> > Thanks,
> > - Mike
> Swift-devel mailing list
> Swift-devel at ci.uchicago.edu
> https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-devel
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20130611/f5985843/attachment.html>
