[Swift-devel] Iterative PageRank in Swift
Michael Wilde wilde at mcs.anl.gov
Sun Jun 2 14:48:58 CDT 2013
Zhao, Im studying this.  Can you post a copy of mapper.sh?
Can you put a copy on a local machine here (both failing and working version) that I can experiment with?
- Mike
----- Original Message -----
> From: "ZHAO ZHANG" <zhaozhang at uchicago.edu>
> To: "Swift Devel" <swift-devel at ci.uchicago.edu>
> Sent: Sunday, June 2, 2013 2:12:30 PM
> Subject: [Swift-devel] Iterative PageRank in Swift
> Dear all,
> I have been working with my cousin on an iterative PageRank
> implementation with Swift for his graduation project. We now
> encounter an problem: we try to use "file fn[]" as intermediate data
> between two stages, however, it does not work well.
> The app and stage definition looks like below:
> zhaozhang at bigben:/var/tmp/workplace$ cat PageRank-new.swift
> type file;
> app (file t) distribution (file f, file s) {
>     distribution @filename(f) @filename(t) @filename(s);
> app (file t[]) partition (file f) {
>     partition @filename(f) "16";
> app (file t) aggregation (file f[]){
>     aggregation @filename(t) @filenames(f);
> app (file t) cat (file f[]){
>     cat @filenames(f) stdout=@filename(t);
> app (file t) sort (file f){
>     sort "-nrk 2" @filename(f) stdout=@filename(t);
> (file fn[])map(file input[], file score){
>    foreach f,i in input {
>       file c<regexp_mapper;
>          source=@f,
>          match="input/(.*)",
>          transform="temp/\\1">;
>       c = distribution(f, score);
>       fn[i] = c;
> (file matrix[][])shuffle(file fn[]){
>    foreach c, j in fn{
> 	file output[] <ext; exec="bin/mapper.sh", source=@filename(c),
> 	scale=16>;
> 	output = partition(c);
> 	foreach f, k in output{
> 		matrix[k][j] = output[k];
> (file final)reduce(file matrix[][]){
>    file result[];
>    foreach fl, k in matrix{
>       file output <single_file_mapper; file=@strcat("result/result-",
>       @toString(k))>;
>       output = aggregation(fl);
>       result[k] = output;
>    final = cat(result);
> If I write the main function as below, it does not work: it seems the
> intermediate files are not mapped to the expected file names.
> //below are main function
> file input[] <filesys_mapper; location="input", prefix="links-">;
> file matrix[][];
> file fn[];
> int loop=0;
> file score <single_file_mapper; file=@strcat("score.txt.",
> @toString(loop))>;
> file final <single_file_mapper;file=@strcat("score.txt.",
> @toString(loop+1))>;
> file sorted <single_file_mapper;file=@strcat("score.txt.",
> @toString(loop+1), ".sorted")>;
> fn = map(input, score);
> matrix = shuffle(fn);
> final = reduce(matrix);
> sorted = sort(final);
> The execution failed with the following message:
> Swift 0.94 swift-r6492 cog-r3658
> RunID: 20130602-1348-yresjj56
> Progress:  time: Sun, 02 Jun 2013 13:48:49 -0500
> Progress:  time: Sun, 02 Jun 2013 13:48:51 -0500  Selecting site:3
>  Checking status:1
> Progress:  time: Sun, 02 Jun 2013 13:48:52 -0500  Selecting site:3
>  Checking status:1  Finished successfully:2
> Progress:  time: Sun, 02 Jun 2013 13:48:53 -0500  Selecting site:3
>  Checking status:1  Finished successfully:4
> Execution failed:
> 	Exception in partition:
>     Arguments: [temp/links-part-0001, 16]
>     Host: localhost
>     Directory:
>     PageRank-new-20130602-1348-yresjj56/jobs/i/partition-ishh5dal
>     stderr.txt:
>     stdout.txt:
> Caused by:
> 	The following output files were not created by the application:
> 	_concurrent/fn-139240b8-81cc-4b22-8088-aa5aedd98afe--array//elt-3-0,
> 	_concurrent/fn-139240b8-81cc-4b22-8088-aa5aedd98afe--array//elt-3-1,
> 	_concurrent/fn-139240b8-81cc-4b22-8088-aa5aedd98afe--array//elt-3-2,
> 	_concurrent/fn-139240b8-81cc-4b22-8088-aa5aedd98afe--array//elt-3-3,
> 	_concurrent/fn-139240b8-81cc-4b22-8088-aa5aedd98afe--array//elt-3-4,
> 	_concurrent/fn-139240b8-81cc-4b22-8088-aa5aedd98afe--array//elt-3-5,
> 	_concurrent/fn-139240b8-81cc-4b22-8088-aa5aedd98afe--array//elt-3-6,
> 	_concurrent/fn-139240b8-81cc-4b22-8088-aa5aedd98afe--array//elt-3-7,
> 	_concurrent/fn-139240b8-81cc-4b22-8088-aa5aedd98afe--array//elt-3-8,
> 	_concurrent/fn-139240b8-81cc-4b22-8088-aa5aedd98afe--array//elt-3-9,
> 	_concurrent/fn-139240b8-81cc-4b22-8088-aa5aedd98afe--array//elt-3-10,
> 	_concurrent/fn-139240b8-81cc-4b22-8088-aa5aedd98afe--array//elt-3-11,
> 	_concurrent/fn-139240b8-81cc-4b22-8088-aa5aedd98afe--array//elt-3-12,
>  1cc-4b22-8088-aa5aedd98afe--array//elt-3-13,
>  _concurrent/fn-139240b8-81cc-4b22-8088-aa5aedd98afe--array//elt-3-14,
>  _concurrent/fn-139240b8-81cc-4b22-8088-aa5aedd98afe--array//elt-3-15
> 	partition, PageRank-new.swift, line 38
> 	shuffle, PageRank-new.swift, line 88
> However, if I put the stages in Iterate control struct: it works.
> file matrix[][];
> file fn[];
> /*iterate loop{
>    iterate i{
>       if (i==0){
>          @toString(loop))>;
>       if(i==1){
>       if(i==2){
>    }until(i==3);
> }until(loop==1);*/
> I also checked SwiftMontage implementation, it was also written in
> this way, so I assumed the first draft should work some time ago. Is
> this a already known problem?
> Best
> Zhao
> Swift-devel mailing list
> Swift-devel at ci.uchicago.edu
> https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-devel
