[Swift-devel] Iterative PageRank in Swift
    ZHAO ZHANG
    zhaozhang at uchicago.edu
    Sun Jun  2 14:12:30 CDT 2013
Dear all,
I have been working with my cousin on an iterative PageRank implementation with Swift for his graduation project. We now encounter an problem: we try to use "file fn[]" as intermediate data between two stages, however, it does not work well.
The app and stage definition looks like below:
zhaozhang at bigben:/var/tmp/workplace$ cat PageRank-new.swift
type file;
app (file t) distribution (file f, file s) {
    distribution @filename(f) @filename(t) @filename(s);
app (file t[]) partition (file f) {
    partition @filename(f) "16";
app (file t) aggregation (file f[]){
    aggregation @filename(t) @filenames(f);
app (file t) cat (file f[]){
    cat @filenames(f) stdout=@filename(t);
app (file t) sort (file f){
    sort "-nrk 2" @filename(f) stdout=@filename(t);
(file fn[])map(file input[], file score){
   foreach f,i in input {
      file c<regexp_mapper;
         source=@f,
         match="input/(.*)",
         transform="temp/\\1">;
      c = distribution(f, score);
      fn[i] = c;
(file matrix[][])shuffle(file fn[]){
   foreach c, j in fn{
	file output[] <ext; exec="bin/mapper.sh", source=@filename(c), scale=16>;
	output = partition(c);
	foreach f, k in output{
		matrix[k][j] = output[k];
(file final)reduce(file matrix[][]){
   file result[];
   foreach fl, k in matrix{
      file output <single_file_mapper; file=@strcat("result/result-", @toString(k))>;
      output = aggregation(fl);
      result[k] = output;
   final = cat(result);
If I write the main function as below, it does not work: it seems the intermediate files are not mapped to the expected file names.
//below are main function
file input[] <filesys_mapper; location="input", prefix="links-">;
file matrix[][];
file fn[];
int loop=0;
file score <single_file_mapper; file=@strcat("score.txt.", @toString(loop))>;
file final <single_file_mapper;file=@strcat("score.txt.", @toString(loop+1))>;
file sorted <single_file_mapper;file=@strcat("score.txt.", @toString(loop+1), ".sorted")>;
fn = map(input, score);
matrix = shuffle(fn);
final = reduce(matrix);
sorted = sort(final);
The execution failed with the following message:
Swift 0.94 swift-r6492 cog-r3658
RunID: 20130602-1348-yresjj56
Progress:  time: Sun, 02 Jun 2013 13:48:49 -0500
Progress:  time: Sun, 02 Jun 2013 13:48:51 -0500  Selecting site:3  Checking status:1
Progress:  time: Sun, 02 Jun 2013 13:48:52 -0500  Selecting site:3  Checking status:1  Finished successfully:2
Progress:  time: Sun, 02 Jun 2013 13:48:53 -0500  Selecting site:3  Checking status:1  Finished successfully:4
Execution failed:
	Exception in partition:
    Arguments: [temp/links-part-0001, 16]
    Host: localhost
    Directory: PageRank-new-20130602-1348-yresjj56/jobs/i/partition-ishh5dal
    stderr.txt:
    stdout.txt:
Caused by:
	The following output files were not created by the application: _concurrent/fn-139240b8-81cc-4b22-8088-aa5aedd98afe--array//elt-3-0, _concurrent/fn-139240b8-81cc-4b22-8088-aa5aedd98afe--array//elt-3-1, _concurrent/fn-139240b8-81cc-4b22-8088-aa5aedd98afe--array//elt-3-2, _concurrent/fn-139240b8-81cc-4b22-8088-aa5aedd98afe--array//elt-3-3, _concurrent/fn-139240b8-81cc-4b22-8088-aa5aedd98afe--array//elt-3-4, _concurrent/fn-139240b8-81cc-4b22-8088-aa5aedd98afe--array//elt-3-5, _concurrent/fn-139240b8-81cc-4b22-8088-aa5aedd98afe--array//elt-3-6, _concurrent/fn-139240b8-81cc-4b22-8088-aa5aedd98afe--array//elt-3-7, _concurrent/fn-139240b8-81cc-4b22-8088-aa5aedd98afe--array//elt-3-8, _concurrent/fn-139240b8-81cc-4b22-8088-aa5aedd98afe--array//elt-3-9, _concurrent/fn-139240b8-81cc-4b22-8088-aa5aedd98afe--array//elt-3-10, _concurrent/fn-139240b8-81cc-4b22-8088-aa5aedd98afe--array//elt-3-11, _concurrent/fn-139240b8-81cc-4b22-8088-aa5aedd98afe--array//elt-3-12, _concurrent/fn-139240b8-81cc-4b22-8088-aa5aedd98afe--array//elt-3-13, _concurrent/fn-139240b8-81cc-4b22-8088-aa5aedd98afe--array//elt-3-14, _concurrent/fn-139240b8-81cc-4b22-8088-aa5aedd98afe--array//elt-3-15
	partition, PageRank-new.swift, line 38
	shuffle, PageRank-new.swift, line 88
However, if I put the stages in Iterate control struct: it works.
file matrix[][];
file fn[];
/*iterate loop{
   iterate i{
      if (i==0){
      if(i==1){
      if(i==2){
   }until(i==3);
}until(loop==1);*/
I also checked SwiftMontage implementation, it was also written in this way, so I assumed the first draft should work some time ago. Is this a already known problem?
Best
Zhao
