[Swift-devel] local tests
    David Kelly
    davidk at ci.uchicago.edu
    Mon Jul 29 08:47:23 CDT 2013
This was related to some changes I am making, sorry about that. The tests/sites/local and tests/sites/local-coasters directories have been restored. I think this should fix the issue with failing tests. I tried to re-run the test suite to verify, but I am running into this when I try to build:
compile:
[echo] [provider-coaster]: COMPILE
[mkdir] Created dir: /swift/swift-0.94/cog/modules/provider-coaster/build [javac] Compiling 134 source files to /swift/swift-0.94/cog/modules/provider-coaster/build
[javac] warning: [options] bootstrap class path not set in conjunction with -source 1.5
[javac] /swift/swift-0.94/cog/modules/provider-coaster/src/org/globus/cog/abstraction/impl/file/coaster/handlers/DeleteHandler.java:21: error: method normalize in class CoasterFileRequestHandler cannot
be applied to given types;
[javac] File f = normalize(getInDataAsString(0));
[javac] ^
[javac] required: RemoteFile [javac] found: String
[javac] reason: actual argument String cannot be converted to RemoteFile by method invocation conversion
[javac] /swift/swift-0.94/cog/modules/provider-coaster/src/org/globus/cog/abstraction/impl/file/coaster/handlers/ExistsHandler.java:21: error: method normalize in class CoasterFileRequestHandler cannot
----- Original Message -----
> From: "Mihael Hategan" <hategan at mcs.anl.gov>
> To: "Yadu Nand" <yadudoc1729 at gmail.com>
> Cc: "Swift Devel" <swift-devel at ci.uchicago.edu>
> Sent: Monday, July 29, 2013 2:46:59 AM
> Subject: Re: [Swift-devel] local tests
> On Mon, 2013-07-29 at 02:23 -0500, Yadu Nand wrote:
> > Hi Mihael,
> > Could you be a bit more specific about tests/sites/local ? I do not
> > think I've made any changes to that folder yet.
> It's missing in SVN:
> https://trac.ci.uchicago.edu/swift/browser/branches/release-0.94/tests/sites
> > Have you noticed that a huge majority of tests are reporting
> > failures
> > since the 26th on Bridled?
> > This is from the 25th ->
> > http://www.ci.uchicago.edu/swift/tests/swift-0.94/run-2013-07-25/tests-2013-07-25.html
> > And from the 26th ->
> > http://www.ci.uchicago.edu/swift/tests/swift-0.94/run-2013-07-26/tests-2013-07-26.html
> That's because that directory is missing. It contains the sites file
> that the tests are supposed to be using.
> > Curiously the tests since the 22nd have been failing for trunk.
> http://www.ci.uchicago.edu/swift/tests/swift-trunk/run-2013-07-22/0041-int-assignment-011635/0041-int-assignment.stdout
> I don't think the tests are failing. They don't seem to be working at
> all.
> Mihael
> Swift-devel mailing list
> Swift-devel at ci.uchicago.edu
> https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-devel
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20130729/78618368/attachment.html>
