[Swift-devel] faster branch merge
    Mihael Hategan
    hategan at mcs.anl.gov
    Mon Jul  8 21:20:05 CDT 2013
Done.
I have also removed the "current" part in cog.
So a checkout now would go something like this:
svn checkout http://svn.code.sf.net/p/cogkit/svn/trunk/src/cog
cd cog/modules
Mihael
On Mon, 2013-07-08 at 17:50 -0700, Mihael Hategan wrote:
> Hello,
> I merged all changes from trunk and 0.94 into the faster branch and ran
> some tests. Seems ok as far as I'm concerned.
> That means that I'm ready to rename trunk to trunk.old and faster to
> trunk. Which probably means that you might need clean checkouts and that
> from now on what used to be the faster branch will become trunk.
> This is the last opportunity to veto this move. I'll wait one hour for
> replies, after which I'm going ahead with the switch.
> Mihael
> Swift-devel mailing list
> Swift-devel at ci.uchicago.edu
> https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-devel
