[Swift-devel] First tests with swift faster
Lorenzo Pesce lpesce at uchicago.edu
Tue Feb 19 14:22:08 CST 2013
Thanks. Implemented, being tested by user.
On Feb 19, 2013, at 1:52 PM, Mihael Hategan wrote:
> The way the site catalog is parsed has changed. I committed a fix in
> svn. A workaround is to make sure you specify a url:
> <execution provider="coaster" jobmanager="local:pbs" url="localhost"/>
> <filesystem provider="local" url="localhost"/>
> The URL is actually required for the coaster provider.
> Mihael
> On Tue, 2013-02-19 at 13:26 -0600, Lorenzo Pesce wrote:
>> This is the content of the file where we have the first complaint from swift (see attached):
>> <config>
>>  <pool handle="pbs">
>>    <execution provider="coaster" jobmanager="local:pbs"/>
>>    <!-- replace with your project -->
>>    <profile namespace="globus" key="project">CI-DEB000002</profile>
>>    <profile namespace="globus" key="providerAttributes">pbs.aprun;pbs.mpp;depth=24</profile>
>>    <profile namespace="globus" key="jobsPerNode">24</profile>
>>    <profile namespace="globus" key="maxTime">172800</profile>
>>    <profile namespace="globus" key="maxwalltime">0:10:00</profile>
>>    <profile namespace="globus" key="lowOverallocation">100</profile>
>>    <profile namespace="globus" key="highOverallocation">100</profile>
>>    <profile namespace="globus" key="slots">200</profile>
>>    <profile namespace="globus" key="nodeGranularity">1</profile>
>>    <profile namespace="globus" key="maxNodes">1</profile>
>>    <profile namespace="karajan" key="jobThrottle">47.99</profile>
>>    <profile namespace="karajan" key="initialScore">10000</profile>
>>    <filesystem provider="local"/>
>>    <!-- replace this with your home on lustre -->
>>    <workdirectory>/lustre/beagle/samseaver/GS/swift.workdir</workdirectory>
>>  </pool>
>> </config>
>> Any ideas?
>> Begin forwarded message:
>>> From: Sam Seaver <samseaver at gmail.com>
>>> Date: February 19, 2013 1:16:28 PM CST
>>> To: Lorenzo Pesce <lpesce at uchicago.edu>
>>> Subject: Re: How are things going?
>>> I got this error.  I suspect using the new SWIFT_HOME directory means that there's possibly a missing parameter someplace:
>>> should we resume a previous calculation? [y/N] y
>>> rlog files displayed in reverse time order
>>> should I use GS-20130203-0717-jgeppt98.0.rlog ?[y/n]
>>> y
>>> Using  GS-20130203-0717-jgeppt98.0.rlog
>>> [Error] GS_sites.xml:1:9: cvc-elt.1: Cannot find the declaration of element 'config'.
>>> Execution failed:
>>> Failed to parse site catalog
>>>        swift:siteCatalog @ scheduler.k, line: 31
>>> Caused by: Invalid pool entry 'pbs':
>>> Caused by: java.lang.IllegalArgumentException: Missing URL
>>>        at org.griphyn.vdl.karajan.lib.SiteCatalog.execution(SiteCatalog.java:173)
>>>        at org.griphyn.vdl.karajan.lib.SiteCatalog.pool(SiteCatalog.java:100)
>>>        at org.griphyn.vdl.karajan.lib.SiteCatalog.buildResources(SiteCatalog.java:60)
>>>        at org.griphyn.vdl.karajan.lib.SiteCatalog.function(SiteCatalog.java:48)
>>>        at org.globus.cog.karajan.compiled.nodes.functions.AbstractFunction.runBody(AbstractFunction.java:38)
>>>        at org.globus.cog.karajan.compiled.nodes.InternalFunction.run(InternalFunction.java:154)
>>>        at org.globus.cog.karajan.compiled.nodes.CompoundNode.runChild(CompoundNode.java:87)
>>>        at org.globus.cog.karajan.compiled.nodes.InternalFunction.run(InternalFunction.java:147)
>>>        at org.globus.cog.karajan.compiled.nodes.FramedInternalFunction.run(FramedInternalFunction.java:63)
>>>        at org.globus.cog.karajan.compiled.nodes.Import.runBody(Import.java:269)
>>>        at org.globus.cog.karajan.compiled.nodes.Main.run(Main.java:79)
>>>        at k.thr.LWThread.run(LWThread.java:243)
>>>        at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1110)
>>>        at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:603)
>>>        at java.lang.Thread.run(Thread.java:722)
>>> On Tue, Feb 19, 2013 at 1:13 PM, Sam Seaver <samseaver at gmail.com> wrote:
>>> OK, it got to the point where it really did hang.  I'm retrying, but with your suggestions.  The other three finished fine!
>>> Progress:  time: Tue, 19 Feb 2013 19:08:53 +0000  Selecting site:18147  Submitted:174  Active:96  Failed:2  Finished successfully:132323  Failed but can retry:183
>>> Progress:  time: Tue, 19 Feb 2013 19:09:23 +0000  Selecting site:18147  Submitted:174  Active:96  Failed:2  Finished successfully:132323  Failed but can retry:183
>>> Progress:  time: Tue, 19 Feb 2013 19:09:53 +0000  Selecting site:18147  Submitted:174  Active:96  Failed:2  Finished successfully:132323  Failed but can retry:183
>>> Progress:  time: Tue, 19 Feb 2013 19:10:23 +0000  Selecting site:18147  Submitted:174  Active:96  Failed:2  Finished successfully:132323  Failed but can retry:183
>>> Progress:  time: Tue, 19 Feb 2013 19:10:53 +0000  Selecting site:18147  Submitted:174  Active:96  Failed:2  Finished successfully:132323  Failed but can retry:183
>>> Progress:  time: Tue, 19 Feb 2013 19:11:23 +0000  Selecting site:18147  Submitted:174  Active:96  Failed:2  Finished successfully:132323  Failed but can retry:183
>>> On Tue, Feb 19, 2013 at 8:51 AM, Lorenzo Pesce <lpesce at uchicago.edu> wrote:
>>> Hmm...
>>> foreach.max.threads=100
>>> maybe you should increase this number a bit and see what happens.
>>> Also, I would try to replace
>>> SWIFT_HOME=/home/wilde/swift/rev/swift-r6151-cog-r3552
>>> with
>>> SWIFT_HOME=/soft/swift/fast
>>> Keep me posted. Let's get this rolling.
>>> if it doesn't work, I can redo the packing.
>>> On Feb 19, 2013, at 1:07 AM, Sam Seaver wrote:
>>>> Actually, the ten agents job does seem to be stuck in a strange loop.  It is incrementing the number of jobs that has finished successfully, and at a fast pace, but the number of jobs its starting is decrementing much more slowly, its almost as its repeatedly attempting the same set of parameters multiple times...
>>>> I'll see what it's doing in the morning
>>>> S
>>>> On Tue, Feb 19, 2013 at 1:00 AM, Sam Seaver <samseaver at gmail.com> wrote:
>>>> Seems to have worked overall this time!
>>>> I resume four jobs, each were for a different number of agents (10,100,1000,10000) it made it easier for me to decide on the app time.  Two of them have already finished i.e.:
>>>> Progress:  time: Mon, 18 Feb 2013 23:50:12 +0000  Active:4  Checking status:1  Finished in previous run:148098  Finished successfully:37897
>>>> Progress:  time: Mon, 18 Feb 2013 23:50:15 +0000  Active:2  Checking status:1  Finished in previous run:148098  Finished successfully:37899
>>>> Final status: Mon, 18 Feb 2013 23:50:15 +0000  Finished in previous run:148098  Finished successfully:37902
>>>> and the only one that is showing any failure (50/110000), is the ten agents version which is so short I can understand why, but its still actively trying to run jobs and is actively finishing jobs, so that's good.
>>>> Yay!
>>>> On Mon, Feb 18, 2013 at 1:09 PM, Lorenzo Pesce <lpesce at uchicago.edu> wrote:
>>>> Good. Keep me posted, I would really like to solve your problems in running on Beagle this week, I wish that Swift would have been friendlier.
>>>> On Feb 18, 2013, at 1:01 PM, Sam Seaver wrote:
>>>>> I just resumed the jobs that I'd killed before the system went down, lets see how it does.  I always did a mini-review of the data I've got and it seems to be working as expected.
>>>>> On Mon, Feb 18, 2013 at 12:28 PM, Lorenzo Pesce <lpesce at uchicago.edu> wrote:
>>>>> I have lost track a bit of what's up. I am happy to try and go over it with you when you are ready.
>>>>> Some of the problems of swift might have improved with a new version and the new system.
>>>>> On Feb 18, 2013, at 12:22 PM, Sam Seaver wrote:
>>>>>> They're not, I've not looked since Beagle came back up. Will do so later today.
>>>>>> S
>>>>>> On Mon, Feb 18, 2013 at 12:20 PM, Lorenzo Pesce <lpesce at uchicago.edu> wrote:
>>>>>> Postdoctoral Fellow
>>>>>> Mathematics and Computer Science Division
>>>>>> Argonne National Laboratory
>>>>>> 9700 S. Cass Avenue
>>>>>> Argonne, IL 60439
>>>>>> http://www.linkedin.com/pub/sam-seaver/0/412/168
>>>>>> (773) 796-7144
>>>>>> "We shall not cease from exploration
>>>>>> And the end of all our exploring
>>>>>> Will be to arrive where we started
>>>>>> And know the place for the first time."
>>>>>>   --T. S. Eliot
>>>>> Postdoctoral Fellow
>>>>> 9700 S. Cass Avenue
>>>>> Argonne, IL 60439
>>>>> (773) 796-7144
>>>>>   --T. S. Eliot
>>>> Postdoctoral Fellow
>>>> 9700 S. Cass Avenue
>>>> Argonne, IL 60439
>>>> (773) 796-7144
>>>>   --T. S. Eliot
>>>> Postdoctoral Fellow
>>>> 9700 S. Cass Avenue
>>>> Argonne, IL 60439
>>>> (773) 796-7144
>>>>   --T. S. Eliot
>>> Postdoctoral Fellow
>>> 9700 S. Cass Avenue
>>> Argonne, IL 60439
>>> (773) 796-7144
>>>   --T. S. Eliot
>>> Postdoctoral Fellow
>>> 9700 S. Cass Avenue
>>> Argonne, IL 60439
>>> (773) 796-7144
>>>   --T. S. Eliot
>> <config>
>>  <pool handle="pbs">
>>  </pool>
>> </config>
>> Any ideas?
>>> y
>>> element 'config'.
>>> Execution failed:
>>>        at
>>>        at
>>>        at
>>>        at
>>>        at
>>>        at
>>>        at
>>>        at
>>>        at
>>>        at
>>>        at
>>>        at
>>>        at
>>>        at
>>>        at
>>>        at
>>>        at
>>>        at
>>>        finished fine!
>>>                Hmm...
>>>                what happens.
>>>                with
>>>> multiple times...
>>>> S
>>>>        successfully:37897
>>>>        successfully:37899
>>>>        that's good.
>>>>        Yay!
>>>>                friendlier.
>>>>> PM, Lorenzo Pesce
>>>>>        ready.
>>>>>        swift might have
>>>>>        improved with a new
>>>>>        version and the new
>>>>>        system.
>>>>>        On Feb 18, 2013, at
>>>>>> looked since Beagle
>>>>>> so later today.
>>>>>> S
>>>>>> Pesce
>>>>>> wrote:
>>>>>> Postdoctoral Fellow
>>>>>> Mathematics and
>>>>>> Computer Science
>>>>>> Division
>>>>>> Argonne National
>>>>>> Laboratory
>>>>>> 9700 S. Cass Avenue
>>>>>> Argonne, IL 60439
>>>>>> (773) 796-7144
>>>>>> "We shall not cease
>>>>>> from exploration
>>>>>> exploring
>>>>>> Will be to arrive
>>>>>> where we started
>>>>>> the first time."
>>>>>>   --T. S. Eliot
>>>>> Postdoctoral Fellow
>>>>> Division
>>>>> 9700 S. Cass Avenue
>>>>> Argonne, IL 60439
>>>>> (773) 796-7144
>>>>> exploration
>>>>> started
>>>>> time."
>>>>>   --T. S. Eliot
>>>>        Postdoctoral Fellow
>>>>        9700 S. Cass Avenue
>>>>        Argonne, IL 60439
>>>>        (773) 796-7144
>>>>           --T. S. Eliot
>>>> Postdoctoral Fellow
>>>> 9700 S. Cass Avenue
>>>> Argonne, IL 60439
>>>> (773) 796-7144
>>>>   --T. S. Eliot
>>>        Postdoctoral Fellow
>>>        9700 S. Cass Avenue
>>>        Argonne, IL 60439
>>>        (773) 796-7144
>>>           --T. S. Eliot
>>> Postdoctoral Fellow
>>> 9700 S. Cass Avenue
>>> Argonne, IL 60439
>>> (773) 796-7144
>>>   --T. S. Eliot
>> Swift-devel mailing list
>> Swift-devel at ci.uchicago.edu
>> https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-devel
