[Swift-devel] First tests with swift faster
Mihael Hategan
hategan at mcs.anl.gov
Tue Feb 19 13:52:56 CST 2013
The way the site catalog is parsed has changed. I committed a fix in
svn. A workaround is to make sure you specify a url:
<execution provider="coaster" jobmanager="local:pbs" url="localhost"/>
<filesystem provider="local" url="localhost"/>
The URL is actually required for the coaster provider.
Mihael
On Tue, 2013-02-19 at 13:26 -0600, Lorenzo Pesce wrote:
> This is the content of the file where we have the first complaint from swift (see attached):
> <config>
> <pool handle="pbs">
> <execution provider="coaster" jobmanager="local:pbs"/>
> <!-- replace with your project -->
> <profile namespace="globus" key="project">CI-DEB000002</profile>
> <profile namespace="globus" key="providerAttributes">pbs.aprun;pbs.mpp;depth=24</profile>
> <profile namespace="globus" key="jobsPerNode">24</profile>
> <profile namespace="globus" key="maxTime">172800</profile>
> <profile namespace="globus" key="maxwalltime">0:10:00</profile>
> <profile namespace="globus" key="lowOverallocation">100</profile>
> <profile namespace="globus" key="highOverallocation">100</profile>
> <profile namespace="globus" key="slots">200</profile>
> <profile namespace="globus" key="nodeGranularity">1</profile>
> <profile namespace="globus" key="maxNodes">1</profile>
> <profile namespace="karajan" key="jobThrottle">47.99</profile>
> <profile namespace="karajan" key="initialScore">10000</profile>
> <filesystem provider="local"/>
> <!-- replace this with your home on lustre -->
> <workdirectory>/lustre/beagle/samseaver/GS/swift.workdir</workdirectory>
> </pool>
> </config>
> Any ideas?
> Begin forwarded message:
> > From: Sam Seaver <samseaver at gmail.com>
> > Date: February 19, 2013 1:16:28 PM CST
> > To: Lorenzo Pesce <lpesce at uchicago.edu>
> > Subject: Re: How are things going?
> > I got this error. I suspect using the new SWIFT_HOME directory means that there's possibly a missing parameter someplace:
> > should we resume a previous calculation? [y/N] y
> > rlog files displayed in reverse time order
> > should I use GS-20130203-0717-jgeppt98.0.rlog ?[y/n]
> > y
> > Using GS-20130203-0717-jgeppt98.0.rlog
> > [Error] GS_sites.xml:1:9: cvc-elt.1: Cannot find the declaration of element 'config'.
> > Execution failed:
> > Failed to parse site catalog
> > swift:siteCatalog @ scheduler.k, line: 31
> > Caused by: Invalid pool entry 'pbs':
> > Caused by: java.lang.IllegalArgumentException: Missing URL
> > at org.griphyn.vdl.karajan.lib.SiteCatalog.execution(SiteCatalog.java:173)
> > at org.griphyn.vdl.karajan.lib.SiteCatalog.pool(SiteCatalog.java:100)
> > at org.griphyn.vdl.karajan.lib.SiteCatalog.buildResources(SiteCatalog.java:60)
> > at org.griphyn.vdl.karajan.lib.SiteCatalog.function(SiteCatalog.java:48)
> > at org.globus.cog.karajan.compiled.nodes.functions.AbstractFunction.runBody(AbstractFunction.java:38)
> > at org.globus.cog.karajan.compiled.nodes.InternalFunction.run(InternalFunction.java:154)
> > at org.globus.cog.karajan.compiled.nodes.CompoundNode.runChild(CompoundNode.java:87)
> > at org.globus.cog.karajan.compiled.nodes.InternalFunction.run(InternalFunction.java:147)
> > at org.globus.cog.karajan.compiled.nodes.FramedInternalFunction.run(FramedInternalFunction.java:63)
> > at org.globus.cog.karajan.compiled.nodes.Import.runBody(Import.java:269)
> > at org.globus.cog.karajan.compiled.nodes.Main.run(Main.java:79)
> > at k.thr.LWThread.run(LWThread.java:243)
> > at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1110)
> > at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:603)
> > at java.lang.Thread.run(Thread.java:722)
> > On Tue, Feb 19, 2013 at 1:13 PM, Sam Seaver <samseaver at gmail.com> wrote:
> > OK, it got to the point where it really did hang. I'm retrying, but with your suggestions. The other three finished fine!
> > Progress: time: Tue, 19 Feb 2013 19:08:53 +0000 Selecting site:18147 Submitted:174 Active:96 Failed:2 Finished successfully:132323 Failed but can retry:183
> > Progress: time: Tue, 19 Feb 2013 19:09:23 +0000 Selecting site:18147 Submitted:174 Active:96 Failed:2 Finished successfully:132323 Failed but can retry:183
> > Progress: time: Tue, 19 Feb 2013 19:09:53 +0000 Selecting site:18147 Submitted:174 Active:96 Failed:2 Finished successfully:132323 Failed but can retry:183
> > Progress: time: Tue, 19 Feb 2013 19:10:23 +0000 Selecting site:18147 Submitted:174 Active:96 Failed:2 Finished successfully:132323 Failed but can retry:183
> > Progress: time: Tue, 19 Feb 2013 19:10:53 +0000 Selecting site:18147 Submitted:174 Active:96 Failed:2 Finished successfully:132323 Failed but can retry:183
> > Progress: time: Tue, 19 Feb 2013 19:11:23 +0000 Selecting site:18147 Submitted:174 Active:96 Failed:2 Finished successfully:132323 Failed but can retry:183
> > On Tue, Feb 19, 2013 at 8:51 AM, Lorenzo Pesce <lpesce at uchicago.edu> wrote:
> > Hmm...
> > foreach.max.threads=100
> > maybe you should increase this number a bit and see what happens.
> > Also, I would try to replace
> > SWIFT_HOME=/home/wilde/swift/rev/swift-r6151-cog-r3552
> > with
> > SWIFT_HOME=/soft/swift/fast
> > Keep me posted. Let's get this rolling.
> > if it doesn't work, I can redo the packing.
> > On Feb 19, 2013, at 1:07 AM, Sam Seaver wrote:
> >> Actually, the ten agents job does seem to be stuck in a strange loop. It is incrementing the number of jobs that has finished successfully, and at a fast pace, but the number of jobs its starting is decrementing much more slowly, its almost as its repeatedly attempting the same set of parameters multiple times...
> >> I'll see what it's doing in the morning
> >> S
> >> On Tue, Feb 19, 2013 at 1:00 AM, Sam Seaver <samseaver at gmail.com> wrote:
> >> Seems to have worked overall this time!
> >> I resume four jobs, each were for a different number of agents (10,100,1000,10000) it made it easier for me to decide on the app time. Two of them have already finished i.e.:
> >> Progress: time: Mon, 18 Feb 2013 23:50:12 +0000 Active:4 Checking status:1 Finished in previous run:148098 Finished successfully:37897
> >> Progress: time: Mon, 18 Feb 2013 23:50:15 +0000 Active:2 Checking status:1 Finished in previous run:148098 Finished successfully:37899
> >> Final status: Mon, 18 Feb 2013 23:50:15 +0000 Finished in previous run:148098 Finished successfully:37902
> >> and the only one that is showing any failure (50/110000), is the ten agents version which is so short I can understand why, but its still actively trying to run jobs and is actively finishing jobs, so that's good.
> >> Yay!
> >> On Mon, Feb 18, 2013 at 1:09 PM, Lorenzo Pesce <lpesce at uchicago.edu> wrote:
> >> Good. Keep me posted, I would really like to solve your problems in running on Beagle this week, I wish that Swift would have been friendlier.
> >> On Feb 18, 2013, at 1:01 PM, Sam Seaver wrote:
> >>> I just resumed the jobs that I'd killed before the system went down, lets see how it does. I always did a mini-review of the data I've got and it seems to be working as expected.
> >>> On Mon, Feb 18, 2013 at 12:28 PM, Lorenzo Pesce <lpesce at uchicago.edu> wrote:
> >>> I have lost track a bit of what's up. I am happy to try and go over it with you when you are ready.
> >>> Some of the problems of swift might have improved with a new version and the new system.
> >>> On Feb 18, 2013, at 12:22 PM, Sam Seaver wrote:
> >>>> They're not, I've not looked since Beagle came back up. Will do so later today.
> >>>> S
> >>>> On Mon, Feb 18, 2013 at 12:20 PM, Lorenzo Pesce <lpesce at uchicago.edu> wrote:
> >>>> Postdoctoral Fellow
> >>>> Mathematics and Computer Science Division
> >>>> Argonne National Laboratory
> >>>> 9700 S. Cass Avenue
> >>>> Argonne, IL 60439
> >>>> http://www.linkedin.com/pub/sam-seaver/0/412/168
> >>>> (773) 796-7144
> >>>> "We shall not cease from exploration
> >>>> And the end of all our exploring
> >>>> Will be to arrive where we started
> >>>> And know the place for the first time."
> >>>> --T. S. Eliot
> >>> Postdoctoral Fellow
> >>> 9700 S. Cass Avenue
> >>> Argonne, IL 60439
> >>> (773) 796-7144
> >>> --T. S. Eliot
> >> Postdoctoral Fellow
> >> 9700 S. Cass Avenue
> >> Argonne, IL 60439
> >> (773) 796-7144
> >> --T. S. Eliot
> >> Postdoctoral Fellow
> >> 9700 S. Cass Avenue
> >> Argonne, IL 60439
> >> (773) 796-7144
> >> --T. S. Eliot
> > Postdoctoral Fellow
> > 9700 S. Cass Avenue
> > Argonne, IL 60439
> > (773) 796-7144
> > --T. S. Eliot
> > Postdoctoral Fellow
> > 9700 S. Cass Avenue
> > Argonne, IL 60439
> > (773) 796-7144
> > --T. S. Eliot
> <config>
> <pool handle="pbs">
> </pool>
> </config>
> Any ideas?
> > y
> > element 'config'.
> > Execution failed:
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > finished fine!
> > Hmm...
> > what happens.
> > with
> > > multiple times...
> > > S
> > > successfully:37897
> > > successfully:37899
> > > that's good.
> > > Yay!
> > > friendlier.
> > > > PM, Lorenzo Pesce
> > > > ready.
> > > > swift might have
> > > > improved with a new
> > > > version and the new
> > > > system.
> > > > On Feb 18, 2013, at
> > > > > looked since Beagle
> > > > > so later today.
> > > > > S
> > > > > Pesce
> > > > > wrote:
> > > > > Postdoctoral Fellow
> > > > > Mathematics and
> > > > > Computer Science
> > > > > Division
> > > > > Argonne National
> > > > > Laboratory
> > > > > 9700 S. Cass Avenue
> > > > > Argonne, IL 60439
> > > > > (773) 796-7144
> > > > > "We shall not cease
> > > > > from exploration
> > > > > exploring
> > > > > Will be to arrive
> > > > > where we started
> > > > > the first time."
> > > > > --T. S. Eliot
> > > > Postdoctoral Fellow
> > > > Division
> > > > 9700 S. Cass Avenue
> > > > Argonne, IL 60439
> > > > (773) 796-7144
> > > > exploration
> > > > started
> > > > time."
> > > > --T. S. Eliot
> > > Postdoctoral Fellow
> > > 9700 S. Cass Avenue
> > > Argonne, IL 60439
> > > (773) 796-7144
> > > --T. S. Eliot
> > > Postdoctoral Fellow
> > > 9700 S. Cass Avenue
> > > Argonne, IL 60439
> > > (773) 796-7144
> > > --T. S. Eliot
> > Postdoctoral Fellow
> > 9700 S. Cass Avenue
> > Argonne, IL 60439
> > (773) 796-7144
> > --T. S. Eliot
> > Postdoctoral Fellow
> > 9700 S. Cass Avenue
> > Argonne, IL 60439
> > (773) 796-7144
> > --T. S. Eliot
> Swift-devel mailing list
> Swift-devel at ci.uchicago.edu
> https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-devel
