[Swift-devel] ui http error on browser
    Ketan Maheshwari
    ketancmaheshwari at gmail.com
    Wed Aug 28 20:35:05 CDT 2013
Hi Mihael,
I tried with the updated version. The log is attached.
In the browser, I type: localhost:8080
The exact message is same as earlier:
Error: The requested resource is not available (in large fonts)
Ketan
On Tue, Aug 27, 2013 at 6:51 PM, Mihael Hategan <hategan at mcs.anl.gov> wrote:
> I added log messages when a request fails. They weren't there before, so
> can you try with the latest trunk?
> Also, can you let me know exactly what URL you typed in the browser
> window? And if possible the exact error message that you got back?
> Mihael
> On Mon, 2013-08-26 at 13:54 -0500, Ketan Maheshwari wrote:
> > Hi,
> > I am trying to run swift trunk (swift-r7005 cog-r3767) to test the new
> http
> > ui feature.
> > When running with -ui http:8080 on midway machine, the browser shows the
> > following error message:
> > It seems the http server starts but is missing index.html or the default
> > file to display. Or something is wrong with my setup.
> > The log for the run is:
> > http://www.mcs.anl.gov/~ketan/catsn-20130826-1846-vgqnbo9b.log
> > Thanks for any suggestions to fix this.
> > Regards,
> > Hi,
> > http ui feature.
> > the following error message:
> > default file to display. Or something is wrong with my setup.
> > Regards,
> > Ketan
> > _______________________________________________
> > Swift-devel mailing list
> > Swift-devel at ci.uchicago.edu
> > https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-devel
Ketan
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20130828/61adbf1f/attachment.html>
Type: application/x-gzip
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20130828/61adbf1f/attachment.bin>
