[Swift-devel] ui http error on browser
Mihael Hategan
hategan at mcs.anl.gov
Tue Aug 27 18:51:56 CDT 2013
I added log messages when a request fails. They weren't there before, so
can you try with the latest trunk?
Also, can you let me know exactly what URL you typed in the browser
window? And if possible the exact error message that you got back?
Mihael
On Mon, 2013-08-26 at 13:54 -0500, Ketan Maheshwari wrote:
> Hi,
> I am trying to run swift trunk (swift-r7005 cog-r3767) to test the new http
> ui feature.
> When running with -ui http:8080 on midway machine, the browser shows the
> following error message:
> Error: The requested resource is not available
> It seems the http server starts but is missing index.html or the default
> file to display. Or something is wrong with my setup.
> The log for the run is:
> http://www.mcs.anl.gov/~ketan/catsn-20130826-1846-vgqnbo9b.log
> Thanks for any suggestions to fix this.
> Regards,
> Hi,
> http ui feature.
> the following error message:
> default file to display. Or something is wrong with my setup.
> Regards,
> Ketan
> Swift-devel mailing list
> Swift-devel at ci.uchicago.edu
> https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-devel
