[Swift-devel] test for "got one name (derr) and 0 values"
Michael Wilde
wilde at mcs.anl.gov
Mon Aug 19 12:03:38 CDT 2013
Ive tested now with provider staging and localhost on communicado. Will now shift to beagle, then try running on the compute nodes using local:pbs.
Can you explain more about what you know and theorize about the problem? Is the error message coming from one of the vdl-int*.k scripts, or a karajan lib method, or ???
- Mike
----- Original Message -----
> From: "Michael Wilde" <wilde at mcs.anl.gov>
> To: "Mihael Hategan" <hategan at mcs.anl.gov>
> Cc: "Swift Devel" <swift-devel at ci.uchicago.edu>
> Sent: Monday, August 19, 2013 11:46:58 AM
> Subject: Re: [Swift-devel] test for "got one name (derr) and 0 values"
> > Just a friendly reminder that lazy errors must be enabled.
> Indeed, and it was, as indicated in ticket 1067 (see below).
> Can you suggest any other adjustments to the test that might trigger
> the problem?
> Are you able to run the test, and is does it replicate the logic you
> sketched?
> Thanks,
> - Mike
> bri$ cat ~/.swift/swift.properties
> sites.file=sites.xml
> tc.file=apps
> wrapperlog.always.transfer=true
> sitedir.keep=true
> file.gc.enabled=false
> status.mode=provider
> execution.retries=5
> lazy.errors=true
> use.wrapper.staging=false
> use.provider.staging=false
> provider.staging.pin.swiftfiles=false
> bri$
> Swift-devel mailing list
> Swift-devel at ci.uchicago.edu
> https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-devel
