[Swift-devel] test for "got one name (derr) and 0 values"
    Michael Wilde
    wilde at mcs.anl.gov
    Mon Aug 19 11:46:58 CDT 2013
> Just a friendly reminder that lazy errors must be enabled.
Indeed, and it was, as indicated in ticket 1067 (see below).
Can you suggest any other adjustments to the test that might trigger the problem?
Are you able to run the test, and is does it replicate the logic you sketched?
- Mike
bri$ cat ~/.swift/swift.properties
sites.file=sites.xml
tc.file=apps
wrapperlog.always.transfer=true
sitedir.keep=true
file.gc.enabled=false
status.mode=provider
execution.retries=5
lazy.errors=true
use.wrapper.staging=false
use.provider.staging=false
provider.staging.pin.swiftfiles=false
bri$
