[Swift-devel] midway jobs not directed to right site
Mihael Hategan
hategan at mcs.anl.gov
Sat Apr 20 00:59:43 CDT 2013
They probably go to the right site, but all of those sites point to
whatever coaster service runs on localhost of which there is only one
(once one is started, whenever you try to run a coaster job on
localhost, the already started service will be used).
So you might want to change the last site to use the local provider
instead.
Mihael
On Fri, 2013-04-19 at 20:32 -0500, Ketan Maheshwari wrote:
> Hi,
> I am trying to run a script where some lightweight jobs were destined to
> run on localhost while others were to run on sandyb/westmere queues in
> midway.
> I do this by putting the right handle before the app name in my tc. The
> corresponding pool entry being in the sites.xml
> However, it looks like all the jobs in the script are running on localhost
> instead.
> When I comment out the localhost part from the sies.xml and the script, I
> correctly get them to run on sandyb/westmere queues.
> In order to verify this, I tried to run a Swift script with three jobs each
> destined to westmere, sandyb and localhost echoing a message and printing
> the hostname. I do find the same behavior in this case too. Jobs were all
> running on localhost and none on the queues.
> See the above mentioned example bundle with logs and config files here:
> http://www.mcs.anl.gov/~ketan/sites_exp.tgz
> Should run straightaway with ./run.midway and . in PATH.
> Feature or bug?
> Hi,
> to run on localhost while others were to run on sandyb/westmere queues
> in midway.
> The corresponding pool entry being in the sites.xml
> localhost instead.
> script, I correctly get them to run on sandyb/westmere queues.
> each destined to westmere, sandyb and localhost echoing a message and
> printing the hostname. I do find the same behavior in this case too.
> Jobs were all running on localhost and none on the queues.
> here:
> Feature or bug?
> Ketan
> Swift-devel mailing list
> Swift-devel at ci.uchicago.edu
> https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-devel
