[Swift-devel] Intrepid
    Ketan Maheshwari
    ketancmaheshwari at gmail.com
    Thu Apr 11 11:32:34 CDT 2013
Thank you. Moving everything to /intrepid-fs0/users/ketan/scratch worked on
Intrepid.
Found from an old Beagle discussion, setting SWIFT_USERHOME to /scratch
path was also required in such cases where the /home filesystem was not
writable by compute nodes.
On Wed, Apr 10, 2013 at 7:09 PM, Justin M Wozniak <wozniak at mcs.anl.gov>wrote:
> Can you try using /intrepid-fs0 ?
> On 04/10/2013 06:47 PM, Ketan Maheshwari wrote:
>  Hi All,
>  Trying to run Swift on Intrepid but jobs are failing. I am using coasters
> with local:cobalt provider.
>  The last error message I am getting is:
>  Job failed with an exit code of 30
>  Apart from this, the std.err also shows this error message:
>  Failed to open log file
> (/home/ketan/lab/catsnsleep/worker-0410-2811160-000000-69be4b00.log):
> Read-only file system at /home/ketan/.globus/coasters/cscript6918.pl line
> 416
>  Line 416 on that perl is:
>  open(LOG, ">>$LOG") or die "Failed to open log file ($LOG): $!";
>  The logs, sources, configs are here:
>  http://www.mcs.anl.gov/~ketan/intrepidlogs.tgz
>  The sites file is yanked from Jon Monette's homedir on Intrepid since
> the dir showed signs of working version. It was with Swift 0.93 and my
> current test is with 0.94 RC though.
>  Thanks much for any help on this.
>  Regards,
> Ketan
> Swift-devel mailing listSwift-devel at ci.uchicago.eduhttps://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-devel
> Justin M Wozniak
Ketan
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20130411/3dad07de/attachment.html>
